Re: * What did you do to your Cobra today? *
bill1024 wrote:Things happen so fast, car is pulling hard, tires break traction
Ahhh ... life behind the wheel of a supercharged Cobra. What a rush!! :drive:
bill1024
Post by bill1024 »
BrettT wrote:Sounds nice!
Like the combo. So you making 9-10lbs? How much more can you get out of the SCi?
Thanks.
I was seeing 4# with the stock pulleys, now it looks to be right between 5 and 10lbs, 7.5 - 8 maybe.
Since I flow better than a stock 93GT/lx Vortech said "I will see less boost on the gauge, but should be flowing much more air than a stock 93".
Looks like 17lbs and 750HP the sci can be maxed to at 53,000 RPM.
http://www.vortechsuperchargers.com/page.php?id=30147
Per their calculator I am spinning @38,000 so I have a ways to go to max it out.
I think I am happy with it right now. For now anyway.
Psychokinesis
Post by Psychokinesis »
Started a wet sand project to remove etched in water spots and scratches. Started with the hatch, removed wing and all.. Looking good so far..pics to follow.
Goose17
Post by Goose17 »
Psychokinesis wrote:Started a wet sand project to remove etched in water spots and scratches. Started with the hatch, removed wing and all.. Looking good so far..pics to follow.
I did the same. Here is the thread:
viewtopic.php?f=1&t=7287&p=71417&hilit= ... ion#p71417
First car show of the season for my Cobra this weekend. Perfect weather for it.
Psychokinesis
Wet sand/polish project complete. Didn't sand the entire car, just places that needed a good reviving. Came out pretty good. The 23 year old paint is showing signs of its age. Still looks good though.
'93BlownCobra
Post by '93BlownCobra »
New rotors and pads front and rear. Tubular rear control arms and bolt on sub frame connectors are next I (don't want to weld on it). LED instrument panel lights next weekend.
~1993 Black Cobra, black cloth, original owner, 8lb Paxton 72K
~2003 Azure Blue Mach 1
~2008 Triple Black Mustang GT Conv
~1985 Black Mustang GT Conv
~1970 Black Mach 1 351C 4V
~1970 Blue Mach 1 351C 4V
~1970 Coral Mach 1 351C 4V
~1981 Red F100 Styleside
~2001 Black SVT Lightning
Psychokinesis
Since I don't smoke, made better use of my cigarette lighter...
That's a good idea, convert the cigarette lighter to an USB hub. I see it had different voltage outlets. Witch one would you use for charging a phone?
Ysi91
Post by Ysi91 »
Installed the rest of the Aeromotive fuel system the other day.
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
Psychokinesis
BrettT wrote:That's a good idea, convert the cigarette lighter to an USB hub. I see it had different voltage outlets. Witch one would you use for charging a phone?
Haven't given it much thought, I know the higher one is the one I am using and it charges my phone pretty quick. I guess it would depend on the phone. I will look into that.
1986Browns
Post by 1986Browns »
Took her for a couple hundred mile cruise today without a hiccup.
Nice! Looks like you took a cruise up a mountain...
1986Browns
BrettT wrote:Nice! Looks like you took a cruise up a mountain...
...you could say that. I live in the Blue Ridge.
Ysi91
Post by Ysi91 »
New hatch oval
93 coupe 91mm turbo
