TKO Swap... finally done!
- jstanley55
Finally got around to doing my TKO swap on Sat. Went pretty smooth but I have a vibration on deceleration and at higher speeds. Symptoms sound like u-joints but installed new spicer u-joints... I think I need the drive shaft balanced. I'm also having a problem with the car not turning over about every other time I go to start it. Thinking this might be a connection to the clutch safety switch, maybe? Anyone have any thoughts?
Here's a few pics I snapped:
TKO 500
Center force dual friction and 31 spline yoke
Stifflers cross member
Billet flywheel
New Bell
MGW (love this shifter)
Wishing I had a two post lift...
Old hunk of grinding and popping junk
Pretty clean for 106k
Broken pilot bearing puller. That sucker was in there.
All done!
TKO 500
Billet flywheel
New Bell
All done!
Stan looks good nice shop, I am currently exploring some tranny options for my coupe. Curious if you know the difference bewtween wide ratio and close ration transmission, I know close will be tight but why would you want wide?
http://www.latemodelrestoration.com/pro ... nsmissions
- jstanley55
I'm no tranny expert but from what I understand for street driving wide is actually better. Easier 1st gear for city driving. Also depends on how your car is geared. if youre running 3:73's and a wide ratio you could be in second before you cross an intersection. The only real difference if you look is first gear. 3.27 vs 2.89 then second is 1.98 vs 1.90 and the other three are identical.JohnLynch wrote:Stan looks good nice shop, I am currently exploring some tranny options for my coupe. Curious if you know the difference bewtween wide ratio and close ration transmission, I know close will be tight but why would you want wide?
Close is good for road racing as there is less drop in rpms between shift.
- jstanley55
Yeah, quality is killer. Plus it came with the proper shims and spacers for the conversion so I didn't need to deal with that part of it. Small issue with spedo cable clearance however.BrettT 93|03 wrote:Nice!
Really like that crossmember!!!
Whenever I break the t5z I'm about to put in my 89, the next transmission I'll be installing will be an astro performance A5: http://www.astroperformance.com/product ... cts_id/751JohnLynch wrote:Stan looks good nice shop, I am currently exploring some tranny options for my coupe. Curious if you know the difference bewtween wide ratio and close ration transmission, I know close will be tight but why would you want wide?
Not to bash tremec in any way, but it seems for every one happy customer there are 2 other who can't hit 3rd gear, find it super clunky, have problem shifting at high RPMs, etc.
Try complaining to tremec, and you'll get no where. With Astro, they happen to be local, so I'll have them install it, and test drive it. If I ever have a problem, I'll take it to them. Tony, the owner, is one great day, and I fully trust he would do his best to take care of someone who had a slight problem with something he sold. However, I don't think it would ever come to that. Numerous people have the A5, and have beaten the crap out of it, and it keeps taking it.
** 89 LX 5.0 ** Currently in hibernation
Wow you sound like a paid spokesman
Clearly you believe that is the direction to go
Kevins89notch5.0 wrote:Whenever I break the t5z I'm about to put in my 89, the next transmission I'll be installing will be an astro performance A5: http://www.astroperformance.com/product ... cts_id/751JohnLynch wrote:Stan looks good nice shop, I am currently exploring some tranny options for my coupe. Curious if you know the difference bewtween wide ratio and close ration transmission, I know close will be tight but why would you want wide?
- jstanley55
Yeah I've heard that too but I've never had an issue with 3rd at all with TKO... I figure that I'm just a better driver than mostKevins89notch5.0 wrote:Whenever I break the t5z I'm about to put in my 89, the next transmission I'll be installing will be an astro performance A5: http://www.astroperformance.com/product ... cts_id/751JohnLynch wrote:Stan looks good nice shop, I am currently exploring some tranny options for my coupe. Curious if you know the difference bewtween wide ratio and close ration transmission, I know close will be tight but why would you want wide?
But if I didn't have this set up already I did run across a t56 complete fox set up (never run) for 3g's and I would have done that. 6sp Cobra would be fun to drive!
Well I'm no stranger to forums, and over the years I've heard people complain about their tremec's non-stop, as well as personal friends have issues as well. I had a tremec 500 for a short time, and found it very notchy, and problematic as well. My setup is a H/C/I/vortech that makes about 450rwhp. When I bought my prior 93 cobra, that killed my savings, so I sold off my tremec setup to free up some money. Every since, I've had my stock t5 and an autozone clutch in. I picked up a free t5z with a blown 3rd gear. I replaced that, and have about $400 into this trans now. I needed some shims to get the t5z back together, so I took Tony the trans, and asked if he could measure it real quick, and sell me the shims I needed. He said no problem, and proceeded to show me around the shop, and show me what sort of work they do there. 10 minutes later a mechanic says he's all done. Not only did he measure to see what shims I needed, but he installed them along with the bearing retainer, and sealed it up and torqued it to specs. I asked Tony how much. He shrugged, looked at the mechanic, and then me. He told me to give the mechanic $20 so he could get some dinner on the way home. That's the type of business man I want to deal with when it comes to a $2,500 transmission, not a faceless company that's far away, and seems to not care that numerous people have problems with their product. I'm not saying the A5 is for everyone, but I'm sold on it.F8L SNK wrote:Wow you sound like a paid spokesman
That is an awesome testimonial.Kevins89notch5.0 wrote:Well I'm no stranger to forums, and over the years I've heard people complain about their tremec's non-stop, as well as personal friends have issues as well. I had a tremec 500 for a short time, and found it very notchy, and problematic as well. My setup is a H/C/I/vortech that makes about 450rwhp. When I bought my prior 93 cobra, that killed my savings, so I sold off my tremec setup to free up some money. Every since, I've had my stock t5 and an autozone clutch in. I picked up a free t5z with a blown 3rd gear. I replaced that, and have about $400 into this trans now. I needed some shims to get the t5z back together, so I took Tony the trans, and asked if he could measure it real quick, and sell me the shims I needed. He said no problem, and proceeded to show me around the shop, and show me what sort of work they do there. 10 minutes later a mechanic says he's all done. Not only did he measure to see what shims I needed, but he installed them along with the bearing retainer, and sealed it up and torqued it to specs. I asked Tony how much. He shrugged, looked at the mechanic, and then me. He told me to give the mechanic $20 so he could get some dinner on the way home. That's the type of business man I want to deal with when it comes to a $2,500 transmission, not a faceless company that's far away, and seems to not care that numerous people have problems with their product. I'm not saying the A5 is for everyone, but I'm sold on it.F8L SNK wrote:Wow you sound like a paid spokesman
- jstanley55
Stock for now. With the Griggs gt-40 suspension I can't fit a 3.5" in it so unless you know someone making a 3" aluminum I will need to get one made and prob going to run $500 or so. Soon, just not quite yet...Mystic1199 wrote:what driveshaft did you install ? i hope after all that work you at least went with an aluminum motorsport one
- jstanley55
So I have some issues... Throwout bearing (or input shaft bearing) started making the typical chirping noise already but to boot when the trans is sitting in neutral I'm getting a kind of "clack clack clack" noise that wasn't there before. Not sure if it could be pilot bearing or what. Anyone have any bright ideas?
I'd be looking at the TOB. What kind did you install when it went back together?jstanley55 wrote:So I have some issues... Throwout bearing (or input shaft bearing) started making the typical chirping noise already but to boot when the trans is sitting in neutral I'm getting a kind of "clack clack clack" noise that wasn't there before. Not sure if it could be pilot bearing or what. Anyone have any bright ideas?
