Page 4 of 6
Re: Early Intakes
Posted: Wed Dec 25, 2013 10:21 pm
by SPEEDFREEK
Looks just about like what I would need to replicate the intake that originally was on my proto.
Re: Early Intakes
Posted: Wed Dec 25, 2013 10:25 pm
by 408lx
SPEEDFREEK wrote:Looks just about like what I would need to replicate the intake that originally was on my proto.
That would probably work for you speed, get the seller to send you a picture of the side view just to make sure it's smooth.
Re: Early Intakes
Posted: Sat Mar 22, 2014 8:43 pm
by Fox9350
Guys is the ridge just a "trivia" type thing or does it hold some value or what? I imagine the intakes are no different except for this cosmetic difference?
Re: Early Intakes
Posted: Sat Mar 22, 2014 8:48 pm
by JohnLynch
Fox9350 wrote:Guys is the ridge just a "trivia" type thing or does it hold some value or what? I imagine the intakes are no different except for this cosmetic difference?
It was a "flow issue" I heard.
Re: Early Intakes
Posted: Sat Mar 22, 2014 10:09 pm
it was a 'harmonics issue" I heard.
Re: Early Intakes
Posted: Sat Mar 22, 2014 10:29 pm
Admin's the winner. The ridge was added to reduce objectionable harmonics created by incoming air in some of the early (smooth) upper intakes. Prior to the switch to the later intake with the ridge, the acoustic characteristics of the smooth intakes were evaluated, and only the "good" units made it to the assembly line.
The engine made the same horsepower/torque regardless of which intake was installed.
Re: Early Intakes
Posted: Sat Mar 22, 2014 10:58 pm
by Fox9350
Does this have any affect on value?
Re: Early Intakes
Posted: Sat Mar 22, 2014 11:28 pm
by JohnLynch
Hey! Air flows I dont get partial credit?
Value? Not really just a convo piece imo
Re: Early Intakes
Posted: Sun Mar 23, 2014 7:22 am
JohnLynch wrote:Hey! Air flows I dont get partial credit?
OK ... partial credit, just this once!
Agree with Lynch on value. Although some may argue that the early build numbers are worth a little more.
Re: Early Intakes
Posted: Sun Mar 23, 2014 1:54 pm
by POOBLAH
Depends on if you own a car with a Early intake or not.
Ownership always dictates how important something is.
Re: Early Intakes
Posted: Sun Mar 23, 2014 2:23 pm
by JohnLynch
POOBLAH wrote:Depends on if you own a car with a Early intake or not.
A pre production car vs early intake car is a different story!
Re: Early Intakes
Posted: Fri Mar 28, 2014 10:09 pm
by JohnLynch
Not that it matters since Z has it narrowed down but just as backup evidence #576 has the ridge intake.
Re: Early Intakes
Posted: Mon Aug 25, 2014 9:56 pm
by s/c-hd2002
Anyone ever see the lower intake that was used with the early no rib uppers? Can anyone confirm that they are the same F3ZE part numbers? I ask because I purchased a lower intake that was supposedly separated from a 93 no rib upper. It has factory spray paint markings on it so it does appear to be a factory installed part.
Re: Early Intakes
Posted: Mon Aug 25, 2014 10:03 pm
by s/c-hd2002
RF-F2ZE-8K461-AA
SAC stamp with paint mark at rear
Re: Early Intakes
Posted: Mon Jun 22, 2015 8:47 am
by BrettT
viewtopic.php?f=7&t=7576
#562 has a flat/smooth sided intake on it!
