Stereo Question
Stereo Question
Q: for you stereo experts. Just had my OEM cassette deck refurbished by Ford repair center and it works great now. Only problem is this....when it is on, and car not started (sitting in garage), it sounds clear with no static or noise. When car is running, and I am moving, I get periodic static and occasional popping. I have original grey spark plug wires (very low miles) but it does the same thing with aftermarket Ford Motorsport wires also, so I don't think it is being caused by the spark plug wires. Could it be the antenna cable needs to be replaced? And yes the cable is plugged in securely to the radio If I do replace it how does it route under the dash? Thanks.
1993 Cobra #2232
Born 4/22/93
Original Owner
Mostly Stock
Born 4/22/93
Original Owner
Mostly Stock
Re: Stereo Question
There was a common issue among SN95s where a buzzing that would increase with acceleration. That turned out to be a lose wire connection (poor ground) near the drivers side kick panel.
Re: Stereo Question
Uhh ... Mr. Grease Monkey, the question was about an OEM radio in a Fox body, not an SN95.
Re: Stereo Question
lolZ282SLO wrote:Uhh ... Mr. Grease Monkey, the question was about an OEM radio in a Fox body, not an SN95.
- Mustang Enthusiast
Re: Stereo Question
Make sure if they added a new grounding wire, it's short as possible.
Re: Stereo Question
What he is saying is true, make sure all your connections are clean on the battery and alternator. Are you sure the connections are tight on the amp side, to the radio and the amp under the passenger seat. Maybe the bouncing around while driving is causing it.escogt wrote:lolZ282SLO wrote:Uhh ... Mr. Grease Monkey, the question was about an OEM radio in a Fox body, not an SN95.
Re: Stereo Question
Man.. nothing gets past you all.Z282SLO wrote:Uhh ... Mr. Grease Monkey, the question was about an OEM radio in a Fox body, not an SN95.
lol... Please... call me Poo (Not to be confused with Shit..... lol)
But yea.. just check the connections. That's a great place to start.
Re: Stereo Question
Thanks I'll give them a look.WillyB93 wrote:What he is saying is true, make sure all your connections are clean on the battery and alternator. Are you sure the connections are tight on the amp side, to the radio and the amp under the passenger seat. Maybe the bouncing around while driving is causing it.escogt wrote:lolZ282SLO wrote:Uhh ... Mr. Grease Monkey, the question was about an OEM radio in a Fox body, not an SN95.
1993 Cobra #2232
Born 4/22/93
Original Owner
Mostly Stock
Born 4/22/93
Original Owner
Mostly Stock
