Page 2 of 2
Re: Rebuild Stock or Modify.. I need opinions
Posted: Sun Apr 23, 2017 8:39 pm
Tk1299 wrote:
Are my numbers similar to yours?
Mine put down 394hp and 439tq on a cool 52 degree day. My KB a 2.2, tuned with an SCT chip. If I recall, 10-11psi as well. It's peak numbers are right around 4k rpm looking at the dyno sheets. Another dyno had the numbers about -10 respectively, not sure if that was the first or second dyno test. If dug through the list of receipts, It would probably tell me.
Your car is putting down some good numbers for sure, plenty of power to have fun with.
My car still has the stock cooling system, so I can tell after driving it around, the blower starts to get heat soaked. Nothing like my Novi 2k, everything stays nice and cool. It pulls like a freight train right all the way through the RPM's, but that's just what they do.
Buddy of mine put a 10psi Vortech kit on a 93 limited with a TFS top end, put just shy of 500hp with a SCT chip and Bob Kurgan tune. Crazy power for a stock block, so if you tune it right, it can last.
Posted: Mon Apr 24, 2017 9:09 pm
by Tk1299
My previous tuner used a Diablo chip, which according to other shops is hard to get right. hopefully this new tuner can dial it in and make it safe and get good numbers. Your torque numbers are awesome and I bet makes it a handful on smooth pavement
Posted: Wed May 17, 2017 10:23 pm
by pete3323
I'm drooling at 400 hp in these cars. Have a '98 cobra as well with terminator drive train putting down 500/500 but I've always thought how fun to have it in my '93.....
Posted: Thu May 18, 2017 6:05 am
pete3323 wrote:I'm drooling at 400 hp in these cars. Have a '98 cobra as well with terminator drive train putting down 500/500 but I've always thought how fun to have it in my '93.....
It's a whole lotta fun!!!
Posted: Sat Jun 10, 2017 11:53 am
by Tk1299
I want to update this cliff hangar, lol. The car is in the shop and the original motor is being pulled and preserved stock. I'm having a 347 stroker motor installed and the Kenne Bell will be put on that. The original motor I will store away so its with the car, just in case. I didn't want to get too crazy and still want it to appear pretty much stock.
Posted: Tue Jun 13, 2017 6:11 pm
Tk1299 wrote:I want to update this cliff hangar, lol. The car is in the shop and the original motor is being pulled and preserved stock. I'm having a 347 stroker motor installed and the Kenne Bell will be put on that. The original motor I will store away so its with the car, just in case. I didn't want to get too crazy and still want it to appear pretty much stock.
Ha, nice! Fire up a new post with the build and any dyno numbers, etc. Will be a tire burner for sure.
Posted: Sat Sep 09, 2017 12:06 am
by pete3323
...any updates on the new build???.....
Posted: Sun Sep 10, 2017 12:15 am
by Tk1299
pete3323 wrote:...any updates on the new build???.....
I had the car back for about three weeks now. I had the original motor removed so it wouldn't be modified and its stored. When I get a shop built ill have it on a stand and display it.
What went into the car was a 347 stroker with forged Pistons, cam, etc.. I also had the .373 gears swapped for .331. It was street tuned but I want to get a dyno tune at some point. It pulls pretty good and makes around 8#s of boost, and is definitely faster than my terminator. I'll take a video of it idling and post it.
But of course there are issues... The Spec stage 2 clutch I had installed is chattering and I keep blowing the #5 fuse(turn signal) upon ignition. I have come to realize that until I have the car undergo a rotisserie restoration into a show quality example, I'll always have some issues with it.
There are bugs here and there to work out still, but I love driving it. Best part is it still looks stock and has cold a/c.
