1993 Cobra Registry
http://www.1993cobra.com
It is currently Mon Apr 23, 2018 1:18 am
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: S-trim @ 18lbs.
PostPosted: Sat Mar 11, 2017 7:12 pm
Offline
Lil S-trim doing work...18lbs.
https://youtu.be/mTzfmGsksXU
_________________
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
Top
 Profile
 Post subject: Re: S-trim @ 18lbs.
PostPosted: Wed Mar 15, 2017 3:53 pm
Offline
I want more video and want to know more about setup......
Top
 Profile
PostPosted: Thu Mar 16, 2017 11:36 am
Offline
Took the 347 out awhile back and sold it to go towards a dart or boss block. The car now has the original shortblock back in. Trick flow heads, tf stage 2 cam, Systemax intake,60lb injectors, aod, s-trim with 8" lower and 3.12 upper. Ran in 2 weeks ago and went a 6.401 at 110 with only a 1.54 60ft. First time with this car at the track. I probably will not run it again until mustang week.
_________________
93 coupe 91mm turbo
Top
 Profile
PostPosted: Tue Mar 06, 2018 8:01 pm
Offline
Wow. How is the stock block taking that power ?!
Top
 Profile
PostPosted: Wed Mar 21, 2018 6:55 pm
Offline
Knock on wood...ok so far.
_________________
93 coupe 91mm turbo
Top
 Profile
PostPosted: Thu Apr 05, 2018 10:38 pm
Offline
Let’s see some pics of this stock block boost monster !
Top
 Profile
PostPosted: Fri Apr 06, 2018 3:18 pm
Offline
_________________
93 coupe 91mm turbo
Top
 Profile
PostPosted: Mon Apr 09, 2018 8:16 pm
Offline
Ysi91 wrote:
And still running AC! Nice
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
Search for:
Jump to:
cron
Powered by phpBB® Forum Software © phpBB Group
