Took the ol heep to the track for the 1st time.
6.401 @ 111mph 1/8th. With crappy 1.54 60ft.
Guess not too bad for an AOD car
https://youtu.be/4DlfiAOsL-w
Drag strip
Drag strip
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
93 coupe 91mm turbo
Re: Drag strip
Nice!
Re: Drag strip
X2! Modified Cobras never get old!
Re: Drag strip
That thing MOVES!
Very nice.
Very nice.
Re: Drag strip
nice launch!
Re: Drag strip
You have a build of this car anywhere? Drag radials and what suspension? Pretty damn good numbers, car left well.
Re: Drag strip
Thanks. Its a 5.0 with trick flow heads,holley intake, s- trim and all the other normal parts. Running a 275-50-15 drag radial. I originally wasn't going to run this car at the track so it had stiff springs (12" 250lb springs) and tokico struts. Since this video the s-trim was sent off and upgraded to a SI, changed out the 8" rear wheels for 10", installed strange adjustable struts and different front springs (14" 150lb springs)buddha wrote:You have a build of this car anywhere? Drag radials and what suspension? Pretty damn good numbers, car left well.
93 coupe 91mm turbo
93 coupe 91mm turbo
Re: Drag strip
WOW! This thing was moving! Very nice. I wasn't expecting it to 60' that hard!
