S-trim @ 18lbs.
Videos of Cobra's or other related
Ysi91
S-trim @ 18lbs.
Post by Ysi91 »
Lil S-trim doing work...18lbs.
https://youtu.be/mTzfmGsksXU
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
TEAL93COBRA3279
Re: S-trim @ 18lbs.
Post by TEAL93COBRA3279 »
I want more video and want to know more about setup......
Ysi91
Re: S-trim @ 18lbs.
Post by Ysi91 »
Took the 347 out awhile back and sold it to go towards a dart or boss block. The car now has the original shortblock back in. Trick flow heads, tf stage 2 cam, Systemax intake,60lb injectors, aod, s-trim with 8" lower and 3.12 upper. Ran in 2 weeks ago and went a 6.401 at 110 with only a 1.54 60ft. First time with this car at the track. I probably will not run it again until mustang week.
93 coupe 91mm turbo
Anthony02tolson
Re: S-trim @ 18lbs.
Post by Anthony02tolson »
Wow. How is the stock block taking that power ?!
Ysi91
Re: S-trim @ 18lbs.
Post by Ysi91 »
Knock on wood...ok so far.
93 coupe 91mm turbo
Anthony02tolson
Re: S-trim @ 18lbs.
Let’s see some pics of this stock block boost monster !
Ysi91
Re: S-trim @ 18lbs.
Post by Ysi91 »
93 coupe 91mm turbo
12SVT
Re: S-trim @ 18lbs.
Post by 12SVT »
Ysi91 wrote:Image
And still running AC! Nice
