Red/leather sunroof #4396 Ebay PA.(SOLD)
For Sale listings of our members cobras.
ramik80 wrote:Yeah, mine doesn't even work Anymore... Only if I raise the volume really high it will work.... So weird
So what do we do? You guys still have the original stock and don't bother touching it???
Sounds to me you are having an amp issue if you have to turn it up most of the way. But the popping is in the radios itself.
ramik80
Post by ramik80 »
You guys are right…. Enjoy listening to the engine!!! I must say it is nice but at the same time it is stock… so its not that loud like a nice flow master would sound… I still love it!!!
Yeah it looks like it the amp, but im hearing all of them do that after a while.
Has anyone every thought of upgrading their radio to a more modern one so is the stock radio that goes in and out good enough… lolol
bdecoy wrote:That is a beautiful car. Got a good look at it from the top tier of the podium when 2946 took first. 4396 is super clean tho. Db u interested in buying my plaque
Congratulations! Nice to see a modded car take first.
bdecoy wrote: U should come down next year three reds would take the hole thing. Black or teal didn't place '12
Maybe I'll join you next year and my modded black will knock your red off the top tier of the podium. 8)
bdecoy wrote: Ya same car red leather roof but highly modded.800hp street car.
800hp?!? That's Nascar Sprint Cup territory. What are you running under the hood?
bdecoy
Post by bdecoy »
AFR 205 Aluminum Heads: 208 intake/1.600 exh. Upgraded springs.
Custom Diamond Pistons: -21.34 cc Forged Lunati Crank: 3.400 stroke
Comp Cams: Custom Grind – Lift 571 int/569 exh – Duration 268/282
Comp Cams Hi Tech Race Timing Set Crane Gold Race Rocker Arms – 7/16” stud mount Scat H-beam Connecting Rods – 5.400” Trick Flow Box R Intake
Accufab 90mm Throttle BodySct3000 Mass AirMoroso 7qt Oil PanGriffin 3 Row Radiator
Polished Vortech YS trim. 2.75 inch blower pulley/8” 22lbs
AIS Stage II- 3 nozzle meth injection. Starts spraying at 8lbs of boost.
Anderson power Pipe with mondo by pass valve.Tremec TKO 900
Spec Stage 5 Clutch Fidenza Aluminum Flywheel Steeda Tri Ax Shifter
Ford Racing Aluminum driveshaft with loop Ford Racing 327 gears Strange Pro Series Differential 31 spline Strange 31 spline Axles TA aluminum cover
welded axle tubes Maximum Motor Sports Sub Frames Hotchkis Caster Camber plates Strange 10 way adjustable struts and rear shocks Q1A coil overs 170 lbs Eibach rear drag springs with airbag
QA1 tublar k member and A arms 2003 10th anniversary brakes
Real Cobra R 5 lugs with correct back spacing for Fox body (M179’s)
Wheels for sale putting 5 lug stock wheels.R's have new tires 555r 05r
Aeromotive Eliminator pump Aeromotive Billet Rails
Aeromotive regulator Stainless lines (-10 line in/-8 return) 100 micron filter in/10 m filter out Siemens 80lb injectors BBK 2.5” Long tubes BBK 2.5” H pipe
2.5 “ FlowMasters
Now before some of u guys come unglued I would never do this to a 12 k mile car but it was already half done and I just wanted to complete it the right way. Will be selling 4" hood and trick flow intake. Going mondo intake stock fiberglass hood w/hole. Will also be selling 88 unmolested white conv 27k and 300 zx white on red 43 k stock looking for teal on black stock or mod low miles. Sorry to get off topic mgt. I'll post pics when I learn how to get pics under 6 kb ha ha
ramik80
Post by ramik80 »
Damn, bdecoy that car seems like it really should be part of NASCAR… lol
I guess it is safe to say if I ever am interested in selling my 4K mile cobra - this site gets first dips!!!
bdecoy - you probably spent a shinny dollar on all those mod’s….
ramik80
Re: Red/leather sunroof #4396 Ebay PA.
Post by ramik80 »
Hey guys,
Might need to let go of my baby ... If anyone interested let me know - I paid 21k and I want 21k.
Car speaks for itself. Only 4,500 miles...
ramik80
Re: (ramik80) Red/leather sunroof #4396 Ebay PA.
Post by ramik80 »
My cell number is 718-757-7860, I can be reached at anytime and will answer any questions you might have. The car is in show room condition.
