Question / Help with 5-Speed
Where is the main bearing located in a Tremec? Is it on the inside or on the front of it. And how had is it to replace, my 5-speed is making a roaring sound. I took it to my dad's speed shop and he told me that it sounds like the main bearing, but he don't do Trasmissions !!!
- 93svt#2779
Re: Question / Help with 5-Speed
did you check the fluid level. when mine was low during my speedo gear swap it made a lot of noise until I was able to get fluid into the tail section again. filled it up and it quieted right down. cheap fix
