what is the duration and lift9T3SVT wrote:Lunati 51025 would I have to change anything to make it work? Can I use stock 1.7's and not worry about piston to valve clearance ?
New Cam
Re: What about this cam !!
thanks.1993cobra wrote:Good fuel injection cam with 5-speed and 4.10 gears or carburetor set up with nitrous.
Ford 351W & 302/5.0L (1982-95)
Hydraulic Roller Camshaft
Lift: .535''/.544''
Duration @ .050'': 224°/232°
RPM Range: 2500-6500
638-51025
info compliments of jeg's
I say no on using that cam with 1.7's because of the exhaust duration and lift.
