pete3323
Posts: 526 Joined: Mon Jul 11, 2011 9:33 pm
Post
by pete3323 » Fri May 25, 2012 10:31 pm
Ok so i have the sensor. When i install it do i have to do anything prior to installation? I don't want the damn air bag to go off! LOL.
'98 White terminated Cobra
'93 Black Cobra #4831
cityboy21
Posts: 328 Joined: Thu Dec 01, 2011 10:12 am
Post
by cityboy21 » Fri May 25, 2012 11:02 pm
pretty sure you need to disconnect the negative battery cable.
1993 Cobra- Teal w/gray cloth #1113(SOLD)
67000 miles
Posts: 4537 Joined: Wed Dec 31, 1969 7:00 pm
Post
by 1993cobra » Sat May 26, 2012 5:36 am
the manual says disconnect the battery , ive done it with and without, just make sure the key is of. When you connect it and turn the key on, its not gonna blow the bag, if something is wrong, you will just get the light and an error code.
pete3323
Post
by pete3323 » Sat May 26, 2012 3:21 pm
OK. Thanks for the help!
pete3323
Post
by pete3323 » Sat Jun 02, 2012 11:37 am
Well i replaced the sensor today and the damn light is still on! Any ideas??
St8-E
Posts: 112 Joined: Fri Aug 13, 2010 7:40 pm
Post
by St8-E » Sat Jun 02, 2012 3:53 pm
do you know anyone with a 93 Mustang who isn't having issues with their air bag? If so, try swapping out the airbag control module which is the blue box located behind the radio...its attached by 2 10mm bolts to a support. It almost looks like an old VCR tape. Its worth trying if you have access to a known good unit...I believe you can ONLY use one from a 93 model though...
Pre-Production # 15, (Teal / Leather), No Sunroof (SOLD)
Shortly looking for a Vibrant/Black cloth
RDLINE1
Posts: 97 Joined: Wed Sep 16, 2009 10:49 am
Post
by RDLINE1 » Sat Jun 02, 2012 4:04 pm
discount battery neg and positive, with them off press the brake pedel. that might work to clear codes..
# 4218
Post
by 1993cobra » Sat Jun 02, 2012 5:10 pm
same code?
pete3323
Post
by pete3323 » Sat Jun 02, 2012 5:58 pm
Already diconnected the battery. Yes, same code 23.
OLLETT
Posts: 64 Joined: Wed Oct 19, 2005 2:06 pm
Post
by OLLETT » Sat Jun 02, 2012 10:41 pm
How could you tell which sensor in the front was bad? I have a flash code of 13. All the description says is front.
Also, does anyone sell sensors brand new?
pete3323
Post
by pete3323 » Sun Jun 03, 2012 1:36 pm
shop looked up the code and said it was drivers rear sensor.
Post
by 1993cobra » Sun Jun 03, 2012 4:30 pm
i looked it up im my service manual
pete3323
Post
by pete3323 » Sun Jun 03, 2012 6:25 pm
And it was the rear sensor, correct? So why is that damn light still blinking at me? LOL.
Posts: 3696 Joined: Wed Apr 04, 2012 3:46 pm
Post
by vinchez78 » Wed Jun 27, 2012 9:15 am
Does anybody know or have known the airbag to deploy while dealing with this issue? That would definitely be a sucky surprise!
pete3323
Post
by pete3323 » Wed Jun 27, 2012 9:18 am
I replaced it with no issues...other than the fact that it didn't fix the problem!
