Tremec 3550 conversion
- jstanley55
Since my t5 is on the way out I am thinking about swapping in a 3550. Has anyone one here done this before? Other than the bell housing, tranny and shifter what else do I need to swap out? Can I use the current clutch cable? What about the driveshaft and crossmember?
Re: Tremec 3550 conversion
I put a 3550 in a 90 gt, and used the same clutch cable, driveshaft and crossmember as I used with the t-5.jstanley55 wrote:Since my t5 is on the way out I am thinking about swapping in a 3550. Has anyone one here done this before? Other than the bell housing, tranny and shifter what else do I need to swap out? Can I use the current clutch cable? What about the driveshaft and crossmember?
Never done the conversion myself, just double check the input and output shaft for correct splines also.
Bolts right up. The only difference is the shifter base between the two. Bell, clutch, and cable will all work.jstanley55 wrote:Since my t5 is on the way out I am thinking about swapping in a 3550. Has anyone one here done this before? Other than the bell housing, tranny and shifter what else do I need to swap out? Can I use the current clutch cable? What about the driveshaft and crossmember?
- jstanley55
- jstanley55
Don't mess with one.jstanley55 wrote:Thanks for the info guys. One more question, what about a 3650? I dont know anything about them. I am assuming its rated for higher torque?
I've had my 3550 in two different cars for years. It's currently in the red car, until I get the TKO-600 in there.
- jstanley55
Dont mess with one because the 3550 is perfectly fine or is there another reason not to? Only asking about the 3650 because I found what looks to. E a good buy on a rebuilt one. But if they are harder to adapt for some reason or not as good I will stick with the 3550.buddha wrote:Don't mess with one.jstanley55 wrote:Thanks for the info guys. One more question, what about a 3650? I dont know anything about them. I am assuming its rated for higher torque?
Yeah, I wish a TKO600 was in the budget!
Thanks
http://www.moderndriveline.com Call them, ask for Bruce tell him Jason sent you. He knows more about Tremec Trans than anyone I have ever met. He rebuilds and sells them for a living. He also rebuilds T5's. I'd recommend you have him rebuild your original Cobra T5 and save the trouble of converting. He gets over 550 RWHP through the T5 in his open track car. He rebuilt the T5 in my 93R (370 rwhp, 400 rwtq), never shifted a better one! It all depends on what you intend to use it for.
-1993 SVT Cobra R #58, open track
-1993 SVT Cobra Teal #112, street
- jstanley55
Funny, I've looked at his site a time or two. I think the shipping would kill me though. I've had two 3550's lined up but didn't get either for one reason or another. I'll call Bruce and get his pricing. Thanks for the info!drkhrse wrote:http://www.moderndriveline.com Call them, ask for Bruce tell him Jason sent you. He knows more about Tremec Trans than anyone I have ever met. He rebuilds and sells them for a living. He also rebuilds T5's. I'd recommend you have him rebuild your original Cobra T5 and save the trouble of converting. He gets over 550 RWHP through the T5 in his open track car. He rebuilt the T5 in my 93R (370 rwhp, 400 rwtq), never shifted a better one! It all depends on what you intend to use it for.
- jstanley55
Just found a killer deal on a rebuilt TKO 500 that I might pick up. I would assume the swap would be the same as the 3550 but I found a few older discussions online saying you need to change the bell...Anyone know for sure?
A tko 500 will require a different drive shaft yoke too.jstanley55 wrote:Just found a killer deal on a rebuilt TKO 500 that I might pick up. I would assume the swap would be the same as the 3550 but I found a few older discussions online saying you need to change the bell...Anyone know for sure?
#2713
