Motor Mount Suggestion?
Guys,
Well, what started out to be a simple exhaust swap has gotten a bit complicated. Found out the motor in my car is sagging a bit and I need new mounts. Basically the BBK shorty headers went in but now the steering linkage won't go back together correctly, and after further inspection the mounts need replacement. Any recommendations?
Thanks,
Tom
Thanks,
Tom
Stock Ford replacements is what I used on all my cars. but don't get convertable mounts as they drop the engine 1/2" and you will have fan/shroud contact.
Here are some options
http://www.latemodelrestoration.com/pro ... tor-Mounts
I got a set from Autozone once and they would not even line up with the bolt bosses in the block. They were made in India!
K98Dave
88 LX hatch -(SOLD
1984 SVO number 110 (SOLD)
93 Cobra Blk# 2100 Still a Virgin- No Mods
95 Lightning (SOLD)
86 LX Restoration in work)
2013 F150 Reg cab Short Bed 5.0
88 LX hatch -(SOLD
95 Lightning (SOLD)
Thanks. Unfortunately all that is shown for the 93 on latemodelresto is the convertable mounts...the stock Ford mounts are for the 4.6...k98dave wrote:Stock Ford replacements is what I used on all my cars. but don't get convertable mounts as they drop the engine 1/2" and you will have fan/shroud contact.
Any other links for stock Ford mounts?
Tom
Try NPD
http://npdlink.com/store/catalog/Factor ... 098-2.html
or PPI @ http://www.performancepartsinc.com.
Ford Dealers may have them in stock
K98Dave
88 LX hatch -(SOLD
95 Lightning (SOLD)
88 LX hatch -(SOLD
95 Lightning (SOLD)
http://www.jegs.com/i/Energy-Suspension ... ProductId=tliss wrote:I am an engine mount virgin here...what are Energy Suspension mounts and where can I get some?buddha wrote:If you go with the Energy Suspension mounts, keep in mind they sit the engine a bit higher.
Also, solid mounts or urethane? Thoughts?
Tom
Looks like they may have changed the design a bit to lower the engine and mimic the vert mounts.
Here is a guy selling a new set discounted a little: http://www.svtperformance.com/forums/en ... ounts.html
- aaronlstiles
