Posts: 3696 Joined: Wed Apr 04, 2012 3:46 pm
Post
by vinchez78 » Sun Dec 23, 2012 8:43 pm
Has anybody turn the ignition further up passed the run position and have it kinda cut off, along with the radio and lights and when turned.back to run position, everything normal?? Happened to me this morning. Any body have this, or is my ignition freaked up?
Posts: 4537 Joined: Wed Dec 31, 1969 7:00 pm
Post
by 1993cobra » Sun Dec 23, 2012 8:46 pm
sometimes they will hang a little , just bump it back and your good, prob. just needs a little lube around the lock cylinder
Post
by vinchez78 » Sun Dec 23, 2012 8:48 pm
I installed a motorcraft one about 2 months ago
Post
by 1993cobra » Sun Dec 23, 2012 8:49 pm
the electrical switch or the lock cylinder and key?
im talking about the lock cylinder the part you insert the key into.
Post
by vinchez78 » Sun Dec 23, 2012 8:50 pm
Yes lock cylinder, not the switch
Posts: 1312 Joined: Sat Apr 09, 2011 5:21 pm
Post
by Romo93 » Mon Jan 28, 2013 6:09 pm
vinchez78 wrote: Yes lock cylinder, not the switch
Vin - What did you do, carjack your black? Or did you buy it and it came with a screwdriver for a key?
Post
by vinchez78 » Tue Jan 29, 2013 12:06 pm
Romo93 wrote: vinchez78 wrote: Yes lock cylinder, not the switch
i plead the fif my brotha
