heater core bypass?
heater core bypass?
Took by car out this morning and noticed it leaking out from firewall. Must be heater core. Want to bypass it where it goes into core at back of motor temporarily until I tackle core replacement. Any one have a part number for a U shaped hose that will work or have any other suggestions. Thanks
#734 Novi 2k 331
- SPEEDFREEK
You cant block the ones off on the motor can you? I thought they had to be looped to circulate.
- SPEEDFREEK
No it needs the hose to loop the circulating water from one side of the heating system to the other. Otherwise you would have no flow.casper wrote:had no problems with mine. only going stop water from heater circulatingSPEEDFREEK wrote:You cant block the ones off on the motor can you? I thought they had to be looped to circulate.
- Mustang Enthusiast
god this post, reminds me of last year... YUCK!
- jstanley55
