Emergency brake handle
Having a problem with Brake handle when I let it down it tends to let down to the left n rub the side of the console is there any way to tighten it up so it will let down straight?
#879 Blk,leather,sunroof
I think the spring in the handle ends up getting some play in it letting it lag to the left toward the drivers seat. Pretty common issue I have seen with these cars and GT's and LX's.
Is it rubbing the console or just the rubber piece? They sell replacement seals if it is damaged. Kinda a PIA to replace since they plastic welded it to the console.
https://www.foxresto.com/products/view/ ... ubber_Seal
