Heater issue
226gpd
Heater issue
Post by 226gpd »
Heater switches from cold to warm but doesn't get really hot. Just replaced the thermostat so I know the motor is warming up. Vacuum issue??
Thanks for any help
2002 Corvette Z06
2000 Saleen 00-0134 (SOLD)
1993 LX 5.0 Coupe Reef Blue (SOLD)
1997 Saleen #59(SOLD)
93 Cobra #418 (SOLD)
2000 Saleen SC281 Convert. (SOLD)
93 Cobra #3398 Black/Gray(SOLD)
93 Cobra #4019 Red/Gray(SOLD)
2003 Cobra Convert. (SOLD)
1996 Saleen (SOLD)
1989 Saleen Convert. #80(SOLD)
Re: Heater issue
226gpd wrote:Heater switches from cold to warm but doesn't get really hot. Just replaced the thermostat so I know the motor is warming up. Vacuum issue??
Thanks for any help
You check your coolant? I know this just happened to my truck and the water pump was bad and it had no coolant.....
226gpd
Post by 226gpd »
Thanks for the reply..Coolant is good. I'm thinking the door that switches from hot to cold is sticking...but I'm not sure..I've owned many fox body Mustangs but never ran into this problem before.
2002 Corvette Z06
1996 Saleen (SOLD)
The cable end tends to break the flapper for the heat to cold, may have to follow the cable to see what is happening.
Probably a partially plugged hater core. Try flushing it out in both directions with a garden hose, a lot of ugly brown muck should wash out. If still luke warm, flush with pool acid cut 1:1 with water, let sit for 5 minutes, flush again. Repeat if necessary. That should do it.
SPEEDFREEK
Post by SPEEDFREEK »
Is the temp coming up like normal? I've seen new thermostats that are bad and stick open. I just did one in another car that did that. It was stuck open and the heat would just get warm it wouldn't get hot.
KeystoneJohnny
Post by KeystoneJohnny »
Mike S. wrote:Probably a partially plugged hater core. Try flushing it out in both directions with a garden hose, a lot of ugly brown muck should wash out. If still luke warm, flush with pool acid cut 1:1 with water, let sit for 5 minutes, flush again. Repeat if necessary. That should do it.
I would say this or the flap due to the cable issue as mentioned by the mod
Toys:
1993 Ford Mustang COBRA # 1118 Black/Black Cloth
2010 Dodge Ram LARAMIE SPORT 4x4 CC.
2005 & 2006 Honda Aquatrax Turbo's
1997 Stingray 190 Bow Rider SS Prop
2010 Kawasaki Z1000
FOR SALE:
2005 Ford Mustang Roush Stage1 (For Sale)
226gpd
Re: Heater issue
Post by 226gpd »
Thanks for all the input..Apparently the heater core was just dirty. I flushed it out today and it is warmer.
2002 Corvette Z06
1996 Saleen (SOLD)
