Page 4 of 6
Re: Airbag diagnosis codes
Posted: Mon Jun 03, 2013 10:41 pm
by jstanley55
I wish you luck my man! Electrical is one thing I despise.
Posted: Tue Jun 04, 2013 11:04 am
by vinchez78
Thanks J, I'm constantly looking for that flash, hope it stays gone
Posted: Wed Jun 05, 2013 11:13 am
by vinchez78
vinchez78 wrote:Thanks J, I'm constantly looking for that flash, hope it stays gone
Well, spoke too soon, was driving this morning on the way to the gym and sure enough freakin airbag flashing, but then after about 10 minutes of flash it stayed off, I was gonna count the flashes later cuz I figured it stay on, but no. :pissed: :ak47: :cussing: :help:
Posted: Wed Jun 05, 2013 11:16 am
by vinchez78
escogt wrote:
She sounds like a keeper, Brah...
She definitely is, P
Posted: Wed Jun 05, 2013 1:25 pm
by Romo93
My cousin Vinnie is having HOT FLASHES? Whoa... :headbang:
Posted: Wed Jun 05, 2013 3:45 pm
by vinchez78
Lol, no womanpause yet but I did count the flashes it's 4 then 5 pause then again. I looked at the last page and it says something about the radiator, can someone elaborate yo?
Posted: Wed Jun 05, 2013 4:29 pm
vinchez78 wrote:Lol, no womanpause yet but I did count the flashes it's 4 then 5 pause then again. I looked at the last page and it says something about the radiator, can someone elaborate yo?
Based on the 45 code, you need to check the LH airbag sensor to make sure its mounted properly. The airbag sensors are mounted to the radiator support assembly with green screws. I'm not sure if left-hand is from the driver's seat or facing the vehicle, so I'd check the sensors on both sides.
Check my post about the airbag sensors towards the bottom of the attached thread -
viewtopic.php?f=7&t=5277&p=49333&hilit= ... ews#p49333
Posted: Wed Jun 05, 2013 8:35 pm
by vinchez78
Awesome Z, so how exactly do you adjust it?? Maybe a new sensor??
Posted: Wed Jun 05, 2013 9:30 pm
Not sure, Vin. I've never had to adjust an airbag sensor. If there are no obvious problems with how your sensors are mounted to the support assembly (i.e. the screws are tight and the sensors appear to be securely attached), you may need a new sensor or maybe someone else will post how they can be adjusted.
Posted: Thu Jun 06, 2013 11:12 am
by vinchez78
Z282SLO wrote:Not sure, Vin. I've never had to adjust an airbag sensor. If there are no obvious problems with how your sensors are mounted to the support assembly (i.e. the screws are tight and the sensors appear to be securely attached), you may need a new sensor or maybe someone else will post how they can be adjusted.
Gotcha, I'm thinking since it's 20 years old it might need a new sensor, anybody know how to replace /adjust airbag sensors??
Posted: Thu Jun 06, 2013 1:15 pm
No adjustment. Unplug connector, remove bolts, swap sensors, replace bolts, connect wire.drink cold beer
Posted: Thu Jun 06, 2013 1:42 pm
That's so easy you can drink cold beer earlier in the process. :mrgreen:
Posted: Thu Jun 06, 2013 4:02 pm
Now we don't need him to unplug the wrong thing. Beer after the repair. :beer:
Posted: Thu Jun 06, 2013 5:51 pm
by Romo93
And Vincent, don't use a hammer anywhere around the airbag sensor! :wavey:
Posted: Thu Jun 06, 2013 8:04 pm
by vinchez78
Lol thanks for the tips fellas :beer: cheers, (spills beer on ground) <-------that's for my dead cobras
