5.0 Cobra Water Pump
Posted: Sun Apr 07, 2013 1:49 pm
Hey,
Ive been recently working on replacing all the seals for my waterpump and timing chain cover. Originally I was planning on using my old waterpump, but as I've been cleaning it, the walls where the gasket meets the aluminum are VERY pitted. I went ahead and bought a remained waterpump from autozone because I was originally thinking I would just replace the plate and use the old pump. (The plate looked awful and the pump didn't look so bad at first) As it turns out.... my rebuilt waterpump I got from Autozone ended up being a original Ford pump (E9TE-8505-AA).
The is only a small difference in the numbers..
My original water pump is E9TE-8505-A4A with a casting date of 1990
The new rebuilt one from Autozone is E9TE-8505-AA with a casting date of 0
Im guessing neither are the "Original pumps" since they don't date to 1992 (car was built in October)
Is there any difference between these two pumps and do you recommend me using the old pump to keep it original or the newer rebuilt one since its also a FORD?
