275/40/17's on stock 7.5 rims
Anybody running 275/40/17's on their stock back wheels? Thinking about running more width in the rear and wanted to know how they would work on the Cobra's 17x17.5 wheels. At the moment I'm running the stock 245/45/17 all the way around.
Re: 275/40/17's on stock 7.5 rims
They are too pinched in, they distort the tire, which affects contact patch, gives wonky handling as the tire squirms around, and look funny. Your best best is to run the aftermarket repro wheels on the back, which are 8.5", and can accommodate the 275/40S.
Thanks for the suggestion. Have a good pair of 275's sitting around and thought about putting them on to fill out the rear more. I may look into the wheels eventually for sure. Thanks again!
But they will work
Anybody have pictures of this tire on the stock rim?
- 93Cobra#2771
They will work, but be advised some tires run wider than other tires. Nitto drags run narrow (have them on the rear on stock rims). I've seen other brands that looked OK as well.
The above pic with the drags on the repro wheel is SICK!
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
93 coupe 91mm turbo
93 coupe 91mm turbo
93 coupe 91mm turbo
93 coupe 91mm turbo
93 coupe 91mm turbo
