Oil pressure gauge
Oil pressure gauge
Oil pressure gauge sits at quarter mark when at idel,when driving it sits at half way mark has anyone had this problem? Don't know if it pump r sending unit
#879 Blk,leather,sunroof
Re: Oil pressure gauge
I know when my oil pressure sending unit went out, my pressure was all the way at the bottom. Freaked me out and thank God it was the opsu. I know the factory gauges are not always accurate....Snake93 wrote:Oil pressure gauge sits at quarter mark when at idel,when driving it sits at half way mark has anyone had this problem? Don't know if it pump r sending unit
They are pretty reasonable form the local parts stores might be worth while to change it and see.
I wouldn't sweat it. I'm guessing it sits a bit higher when it's still cold, and works it's way down once the oil is up to temp. Besides, these little 302's can run pretty loose for a long time.
