As far as the 15 lb cap, I was merely quoting what it said on my bottle of antifreeze, I,m not even sure how many lbs my cap is, nor am I sure of what the difference is.vinchez78 wrote:Thanks again fellas, so the 50/50 is better than adding water to just coolant huh? And the 15 lb cap is the way to go?
Time for a new Radiator!
- 93svt#2779
Re: Time for a new Radiator!
50/50 is cheap and easier. Did you start the project yet?
The stock Motorcraft radiator cap in the Cobra is a 16 lb cap.93svt#2779 wrote:As far as the 15 lb cap, I was merely quoting what it said on my bottle of antifreeze, I,m not even sure how many lbs my cap is, nor am I sure of what the difference is.vinchez78 wrote:Thanks again fellas, so the 50/50 is better than adding water to just coolant huh? And the 15 lb cap is the way to go?
16lbs. indeed.
Not yet, gotta study for a test, as soon as I'm done I'll get distilled water and the coolant and get startedRomo93 wrote:50/50 is cheap and easier. Did you start the project yet?
Anymore "check coolant" issues?
I think I got it squared away ROMOMOMO, thanksRomo93 wrote:Anymore "check coolant" issues?
