Stock 1993 Cobra Fuel Pump
vuzikis
Post by vuzikis »
Does anyone know the specs on the stock Ford fuel pump for the 1993 GTs and Cobras. Research is telling me the 1993 GTs and Cobras had the same pump. Is the stock pump 90lph? I believe mine is just about done.
Re: Stock 1993 Cobra Fuel Pump
Your research is correct. All 86 thru 93 5.0 Mustangs, inc. the Cobra, had the same fuel pump with delivery rate of 88.2 lph. Many production pumps are marked with a 95 lph designation.
vuzikis
Post by vuzikis »
Ok good. Prolly going to buy the BBK 110lph and be done. I open track my car from time to time and would like to keep it on the richer side anyway. IMO Ford should of upgraded the fuel pump on Cobras anyway being the car has larger heads, intake and fuel injectors over GTs and LX 5.0 models.
That unit will work fine, especially on a stock motor. A 190 lph unit works nice with most engine mods. I use an Edelbrock 255 lph in-tank & a T-Rex external with my supercharged motor.
