plugs for supercharger?
COBRAJR707
Post by COBRAJR707 »
Hey guys, which plugs should i be running with my V3 vortech si supercharger? pushing about 10 lbs of boost.
#3851 red/graycloth/sunroof
91 GT burgundy/titanium gray cloth
92 GT black/titanium gray cloth sunroof (sold)
96 GT burgundy/peanut butter convertible (sold)
88 GT white/titanium red cloth (RIP)
Dixie789456
Re: plugs for supercharger?
Post by Dixie789456 »
Off topic, but how was the install? Bout to order the same kit for my cobra.
I'm using Autolite plugs with a V2 at 10 lbs.
COBRAJR707
Dixie789456 wrote:Off topic, but how was the install? Bout to order the same kit for my cobra.
Not bad, worst part for me was making the hole larger for the power pipe.
COBRAJR707
Z282SLO wrote:I'm using Autolite plugs with a V2 at 10 lbs.
Which autolites did you go with? Did you go 1 heat range colder?
Ysi91
Post by Ysi91 »
NGK -8 here with s-trim @ 15lbs.
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
bdecoy
Post by bdecoy »
Ysi91 wrote:NGK -8 here with s-trim @ 15lbs.
X2 NGK double prong all day! :humps:
COBRAJR707 wrote:Which autolites did you go with? Did you go 1 heat range colder?
Autolite 764 copper core plugs with Taylor 409 Pro Race wires. Not sure about the heat range. Speed shop did the plugs & wires.
svtfamily619
Post by svtfamily619 »
does vortech still make a bolt on
kit for 93 cobras?
svtfamily619 wrote:does vortech still make a bolt on
kit for 93 cobras?
Yes. There's a V3 setup (and probably others) for the 93 Cobra.
ssuro11
Post by ssuro11 »
Any tips for rebuilding the engine for a supercharger? Looking at going with a vortech around 10lbs on my 93. I am about to order the fuel pump and replace all of the fuel tank. Would a 255 be enough or do I need a 340?
A 255 will work fine.
COBRAJR707
ssuro11 wrote:Any tips for rebuilding the engine for a supercharger? Looking at going with a vortech around 10lbs on my 93. I am about to order the fuel pump and replace all of the fuel tank. Would a 255 be enough or do I need a 340?
I went with a 340lph, 60# injectors and 80mm maf. Make sure you have MLS head gaskets.
More than u need at 10lbs IMO. I'm using a 255 with 42lb injectors and a 80mm MAF at 10lbs.
Ysi91
Post by Ysi91 »
I went with a 340lph, 60# injectors and 80mm maf. Make sure you have MLS head gaskets.[/quote
340lph with 60's here too
93 coupe 91mm turbo
