plugs for supercharger?
Re: plugs for supercharger?
Ysi91 wrote:340lph with 60's here too
What type of blower and boost are you running?
Dixie789456
Post by Dixie789456 »
Putting my v3 sci kit on this friday if everything shows up! Went with the base 5-6 psi since I wanted to keep everything pretty much stock.
Ysi91
Post by Ysi91 »
Vortech SQ trim @ 15lbs
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
svtfamily619
Post by svtfamily619 »
Guys can you help me?..whats the part # for the V3 kit your running?..all I see is a kit for the regular 5.0 fox bodys, that's not what I need right?, or are you all just bolting that kit on and using an FMU for 24# injectors instead of the kits FMU for the 19#'s...I know no FMU and a tune is my best option but I have nowhere close that can tune and I dont want to mod the car much more than a true bolt on kit..Vortechs website says the only kit for a 93 cobra is discontinued..thanks for the help!!
Ysi91
Post by Ysi91 »
Any 86-93 kit will work on your cobra. This is from Anderson Ford.
93 coupe 91mm turbo
COBRAJR707
Post by COBRAJR707 »
Z282SLO wrote:^^^
More than u need at 10lbs IMO. I'm using a 255 with 42lb injectors and a 80mm MAF at 10lbs.
Went bigger with the injectors in case I ever wanted to go with more boost in the future. Was recommended by Bob Kurgan. Wasn't that much more in price.
#3851 red/graycloth/sunroof
91 GT burgundy/titanium gray cloth
92 GT black/titanium gray cloth sunroof (sold)
96 GT burgundy/peanut butter convertible (sold)
88 GT white/titanium red cloth (RIP)
Two Coupes
Post by Two Coupes »
Hey there, On my 13ish PSI 570whp (mustang dyno) '89 coupe I ran Autolite 3923. I had an MSD ignition and coil and never had reason to believe that I had the spark blow out problem. Lot of guys gap them real tight to prevent that. If your ignition is stock you may need to. I think I was gapped at 50. (Kind of wide I guess being boosted.) Super Conductor wires too...
COBRAJR707
I think I'm gonna go with auto lite 3923s. Should I get the iridium ones? Or just stick with the copper ones?
Copper should be fine.
COBRAJR707
Finally got around to installing some autolite 3923s. She runs so much better now under boost at top end. Thanks guys for all the input! Appreciate it!
jsmithgt500
Post by jsmithgt500 »
svtfamily619 wrote:Guys can you help me?..whats the part # for the V3 kit your running?..all I see is a kit for the regular 5.0 fox bodys, that's not what I need right?, or are you all just bolting that kit on and using an FMU for 24# injectors instead of the kits FMU for the 19#'s...I know no FMU and a tune is my best option but I have nowhere close that can tune and I dont want to mod the car much more than a true bolt on kit..Vortechs website says the only kit for a 93 cobra is discontinued..thanks for the help!!
Did you decide on your setup? Using Stock 24's, Maf, and the FMU? Wondering if staying around 8psi would the stock items work?
jsmithgt500 wrote:Wondering if staying around 8psi would the stock items work?
If staying with stock items, I'd recommend no more than 5-6 lbs of boost. Anything higher and you should consider upgrades to injectors, fuel pump, MAF, etc.
jsmithgt500
Ive seen people run 8psi using the stock maf and 24s. The pump would be replaced with an Aeromotive 340.
So have I. But the car will perform better if you increase the air & fuel getting to the engine at that boost level.
jsmithgt500
Couldn't agree more. Just curious if people have done a stock setup plus blower.
