Idling problem
SVT#3140
Idling problem
Post by SVT#3140 »
I had a ''so-call '' mech..change all that list's below .my car went to him running perfect . now after changing the parts that's list below my car idleing crazy and revving up and down push the gas rpm stay for a few seconds then comes down ..now he can't sort the problem out .
NEW .....battery ,130 amp alternator with new upgraded power wire , cold air intake finder wall , mass air meter for 24 Lb injector, idle air control, air charge temp sensor, coolant temp sensor, oil pressure sending unit , EGR valve, change a few vacuum lines and throttle position sensor . set @ 0.98 volts & wide-open throttle is 4.67 volts...
any input or suggestions will help .
SVTchris
Re: Idling problem
Post by SVTchris »
Maybe this can help:
http://www.fordmuscle.com/archives/2002 ... ndex.shtml
Good luck with your problem.
1993 SVT Mustang Cobra
2004 SVT F-150 Lightning
Re: Idling problem
SVT#3140 wrote: cold air intake finder wall , mass air meter for 24 Lb injector, idle air control, air charge temp sensor, coolant temp sensor, oil pressure sending unit , EGR valve, change a few vacuum lines and throttle position sensor
-What MAF was installed? I hope not a C&L............those things are junk.
-Check for any vacuum leaks, a lot of what was touched has a line running to it
-Verify the IAC
I would take it back to him, he should make it right for you.
SVT#3140
Re: Idling problem
Post by SVT#3140 »
-Verify the IAC
BBK Mass air
TEAL93COBRA3279
Re: Idling problem
Post by TEAL93COBRA3279 »
If car was running fine, why did you change all that? I would start with putting stock mass air back on.
SVT#3140
Re: Idling problem
Post by SVT#3140 »
TEAL93COBRA3279 wrote:If car was running fine, why did you change all that? I would start with putting stock mass air back on.
Far as changing all them parts .....i figured that i will start to change out some sensor and do some upgrading .... not thinking that putting on new part's would end up like this . maybe it's not the new parts .just the mech .
1986Browns
Re: Idling problem
Post by 1986Browns »
If it ain't broke, don't fix it!!!
Re: Idling problem
This for sure, see how it does.
