Experience Mechanic
SVT#3140
Experience Mechanic
Post by SVT#3140 »
Anyone know a experience mechanic or experience shop that works on 93 cobra's in southeast Louisiana .
Winchester
Re: Experience Mechanic
Post by Winchester »
Sorry, if you were in AZ or IL I could point you in right direction.
I'd do a search for guys that tune mustangs if your in a pinch. Both places I'm thinking of are tuners who do mostly mustangs but they have a full service shop too.
What were you looking to get done?
SVT#3140
Post by SVT#3140 »
Winchester wrote:Sorry, if you were in AZ or IL I could point you in right direction.
Car Has high idle , vacuum leaks ..not running good
Like it was mentioned, any local tuners that work on Fox Mustangs could knock it out in a day or so. But to that, any decent mechanic could as well.
Might look at a few places toward the Texas area, I bet there is a few somewhat close to you there.
SVT#3140
Post by SVT#3140 »
buddha wrote:Like it was mentioned, any local tuners that work on Fox Mustangs could knock it out in a day or so. But to that, any decent mechanic could as well.
Car was at local hot rod shop , and 11 hours of labor and change EGR position sensor ,EGR pressure sensor, IAC gasket & 02 sensors . ..and car was there 2 1/2 weeks .
Wow, ya, wrong damn shop for sure.
Were are you located?
SVT#3140
Post by SVT#3140 »
New Orleans Area .
Winchester
SVT#3140 wrote:Anyone know a experience mechanic or experience shop that works on 93 cobra's in southeast Louisiana .
Did you have any luck?
SVT#3140
Post by SVT#3140 »
Yes found a shop in Slidell, La .... talking with the shop owner he works on a lot of foxbody mustang .sooo hopefully i found a good shop .
Winchester
Sounds like you're on the right track. Hope it pans out for you.
SVT#3140
Post by SVT#3140 »
What a difference when you can find a good mechanic to work on your car and know's what he is doing !! :drive:
Yep, there are bad ones out there.
So what was the fix for yours?
SVT#3140
Post by SVT#3140 »
buddha wrote:Yep, there are bad ones out there.
Replace lot of vacuum lines , fix upper intake gasket that was leaking , replace flywheel ,clutch , clutch cable , starter , service the AC . And Dyno & Tune the car..
Winchester
Thats good to hear. What did it put down on the dyno?
