1977 Cobra
1977 Cobra
http://flipacars.com/pics/Ford/ford-mus ... -ii-02.jpg
I know most people hate these cars but I like this one in particular nice stance, anyone else like it?
Re: 1977 Cobra
The Mustangs from 74 thru 78 are a sad chapter in Ford's history. A Mustang II with tacky body add-ons, decals and a 140hp(!!) V8 should never have been called a Cobra.
At least the one in the pic is BLACK.
Re: 1977 Cobra
John? Is this you?JohnLynch wrote:http://flipacars.com/pics/Ford/ford-mus ... -ii-02.jpg
Re: 1977 Cobra
I dont care much for them but that one looks great.
Re: 1977 Cobra
Yuk and nice at the same time.
Agree John, the stance does make the car look better and also the black paint.
Re: 1977 Cobra
Never cared for that generation of Mustangs... never will.
Re: 1977 Cobra
I've always liked Cobra IIs, the main problem that I have with the Mustang II in general is the forward placement of the engine relative to the front axle center line. It's too far forward, which leads to wonky handling and tire scrub. Set the firewall back to move the engine rearward, and you lose leg room. No easy way to make the car work with big power.
Re: 1977 Cobra
What do you expect from a design based on the Pinto? In addition, big power was never an issue with these models.Mike S. wrote:I've always liked Cobra IIs, the main problem that I have with the Mustang II in general is the forward placement of the engine relative to the front axle center line. It's too far forward, which leads to wonky handling and tire scrub. Set the firewall back to move the engine rearward, and you lose leg room. No easy way to make the car work with big power.
Re: 1977 Cobra
Ya, bad years for the Stang for sure.
Still, one of the best burnouts I ever witnessed was by a guy in HS at a party. He yanked the motor and did some work too it and ran pretty decent for the time.
Re: 1977 Cobra
vinchez78 wrote:DB LOOOOOVES MUSTANG II's
Re: 1977 Cobra
More. The Pinto was a solid little car with a tough, compact suspension design that is still #1 in the hot rod/street rod world by a large margin. Pintos themselves are the cars to beat at dirt tracks all over the country in the entry-level pony stock division. It would have been nice if they pulled the front axle forward 3" on the M-II and used a Fox style oil pan. That would have taken care of the main problem with these cars, plus the styling would have benefited from the reduced front overhang.Z282SLO wrote: What do you expect from a design based on the Pinto?
In stock form. I'm talking about what most enthusiasts do to Mustangs, hot rod them.In addition, big power was never an issue with these models.
Re: 1977 Cobra
With the exception of the Pinto being a flaming deathtrap, it was a decent little car.
Re: 1977 Cobra
Mike S. wrote:More. The Pinto was a solid little car with a tough, compact suspension design that is still #1 in the hot rod/street rod world by a large margin. Pintos themselves are the cars to beat at dirt tracks all over the country in the entry-level pony stock division. It would have been nice if they pulled the front axle forward 3" on the M-II and used a Fox style oil pan. That would have taken care of the main problem with these cars, plus the styling would have benefited from the reduced front overhang.Z282SLO wrote: What do you expect from a design based on the Pinto?
Good points
