iM working on building the correct engine for my car I need valve covers,heads,cam and cold air box mass air meter and all.
cobra parts needed
Re: cobra parts needed
Here's some other recommended items for returning your car's engine bay to stock - ignition coil cover, Motorcraft battery, distributor cap cover, plug wires, and the three stickers for the radiator support assembly ('coolant service', 'air conditioner' & '5.0L Drive Belt Installation'). You'll have to remove the buck tag if you want to correctly place the 'coolant service' sticker.
I may have the distributor cap cover. Let me know if you're interested in that, and I'll search for it. Good luck on your project!
yep that buck tag goes behind the left headlight,
