wanted 93 vortec superchager set up
looking for a complete or as complete a setup as possible dont need injectors or fuel pump maf or throttle body just everything else that it takes to mount the supercharger including fmu and other little things hoses brackets air pipe from supercharger to throttle body.etc whatever it takes to make it work
Re: wanted 93 vortec superchager set up
If your having computer issues, it might be best to have a computer tuned to the exact setup you have once you put the SC on. Then you wouldn't have to have the FMU setup, just the bigger injectors, fuel system work and MAF and the tune. Might just shop around for the specific setup you are wanting, Vortech, Novi, Kennebell.
decided to go a little different route getting a new kenne bell sc for it and yes later will have to get a tune for it as well.
