88 coupe
New parts- PA Performance Comp Tuff C-4 transmission with bell housing (reverse manual valve body-Borg Warner clutches-Kevlar band-teflon rings-pro shift billet servo-lightened internals-good to 650hp)
PTC 10" torque converter
Hughes locking dipstick tube
Holcomb trans cooler w/braided lines and A/N fittings
50oz balance 157t flywheel
B&M Pro Stick shifter with reverse gate plate
MSD 6AL ignition box
RCI 5gal aluminum fuel cell
Painless wiring harness-radio mount w/rocker switches
Moroso electric water pump drive
Manual rack and pinion steering rack w/ tie rod ends and solid shaft joint-installed
ASP manual brake conversion-installed
Competition Engineering 10pt roll cage
Poly race seat w/ cover
Comp thru the floor subframe connectors-installed
2 15x10 Weld Draglite wheels for the rear-new in box-5 lug dual pattern 7.5" backspace
Holley red electric fuel pump
ARP flywheel bolts
1" carb spacer
Art Morrison coil over shocks for the rear-installed
Used parts-
Roll of aluminum fuel line
5pt safety harness
Mallory series 500 fuel filter w/ A/N fittings-has new filter and o-ring
Holley fuel pressure regulator
Electric fan
Fuel pressure guage for under hood use
4" fiberglass cowl hood
Accel super coil
MSD distributor for a 302 w/ steel gear
Edelbrock Performer RPM aluminum intake for 302
Holley 650 double pumper carb-fresh rebuild
2 15x3.5 Weld Draglite wheels with tires- on car
8.8 rear end w/3.73 gears trac loc and 5 lug conversion
Hedman long tube headers for 302 in a fox mustang
Will try to have pics up Friday
Over $5500 invested will sell all for $2900
PM, reply to post or e-mail mperkins3965 <@> charter <.> net
just remove <> and spaces to e-mail
88 Coupe race car project Pics added
Moderator: WillyB93
Proud owner of 93 Cobra #1928
Black/Gray leather
Black/Gray leather
post some pics of it.
- ceetwarrior
