eagle crank
eagle rods
mahle pistons
afr 185 heads
ford motorsport camshaft
zero balance motor
trick flow intake
upr k-member kit
long tube headers
ptc c-4 trans with ptc converter with trans brake
flex-a-lite 185 fan assembly
1.6 roller rockers
comp push rods
msd 6al ignition
painless wiring 4 switch panel in the console
nx nitrous kit (plate between intakes)
with nano nitrous kit
30 LB INJECTORS
75 MM THROTTLE BODY
80 MM C&L MASS AIR WITH 3.5" INLET PIPE
AJUSTABLE FUEL PRESSURE REGULATOR & GAUGE
WALBRO 255 FUEL PUMP
ALUMINUM RADIATOR
MSD 6AL, MSD 2-STEP, MSD COIL
31 SPLINE MOSER AXLES & 3.73 GEARS
GRANETELLI UPPER & LOWER CONTROL ARMS
SUBFRAME CONNECTORS
TORQUE BOX REINFORCEMENTS
LAKEWOOD 50/50 SHOCKS & 90/10 STRUTS
WELD DRAGLITES 8" REAR 3.5" FRONT
and factory cobra wheels
3" COBRA R HOOD
SMOKED HEAD LIGHTS & FOG LIGHTS
limo tinted windows with new tinted windshield
black 95 mustang seats in front
very fast
still have alot of the factory stuff that can be put back on if wanted
new motor has only 450 miles on it and the nitrous has not been used
2563020313 and leave message
1993 mustang cobra red
http://atlanta.craigslist.org/atl/cto/2482716215.html
Red/ ?? Modded $14000 GA
