Own the only year of the Fox body Mustang Cobra, for $9,950!
Original vibrant red 1993 Ford Mustang Cobra with opal grey leather interior has only 104k miles. This car has a clear title. '93 was the first year Ford brought back the Mustang Cobras and the only year of the Fox body Cobras. It has never been wrecked or repainted. The hood has swirl marks and some minor water spotting on the horizontal paint surfaces due to the original owner not storing it in a garage. This cobra has been in a garage since 1998, with a brief 6 month period of being parked outside with a California car cover (included) when initially I got married.
Mileage 1038xx
Exterior is in good shape. The exterior has paint chips typical of a 100k mile car and the black mirror housings have started to wear, but are touched up.
The interior is in good shape. There is a small tear in driver's seat and a small crack in the plastic interior wheel cover. The ashtray was broken and has since been repaired.
I hate to see her go, but I just don't have time for a car hobby right now.
Modifications:
Full Griggs Racing GR-40
Front coilovers have 400-lb springs installed.
Tubular K-member installed
Tubular lower control arms
Bump steer has been adjusted
Griggs Delrin bushings installed
Maximum Motorsports Caster/Chamber plates
Koni Yellow adjustable shock/struts
Torque Arm & Heavy duty Panard Bar
Rear Control arms with Delrin bushings
Rear springs are 400-lb. Additional 350-lb springs and spring perch jacking screws are included.
Car has been corner balanced for 190 lb driver.
Battery relocated to trunk
Brake cooling ducts installed in fog light openings
Steeda Aluminum clutch quadrant with firewall adjuster
3.55 rear differential
Griggs Aluminum Driveshaft
Steeda short throw shifter
Jet hot coated unequal length headers
Bassani X pipe with catalytic converters
Porterfield R4S performance brake pads
Wilwood brake proportioning valve
Braided brake lines
Clifford Alarm
Under drive pulleys
K&N air filter
New King Cobra clutch
New Falcon Azentis tires have less than 500 miles on them. Driver side rear tire has a plug.
Replaced heater core.
Cooling hoses were replaced with blue silicone hoses
Will include (not on car)
350 lbs rear springs and jacking screws
Steeda Strut tower brace
Used spare front rotors
SN95 front spindles
5 lug Tri spoke wheels- ready for future five lug conversion
California car cover (I believe the fabric is NOAH, but I bought it over a decade ago)
MSD ignition (NIB), never installed on car
OBD II scanner
Official Ford Manuals
Haynes Manual
Mustang Performance Handbook 1 William Mathis
Mustang Performance Handbook 2 William Mathis
Performance Handling Don Alexander
Drive to Win Carrol Smith
Misc. Mustang specific tools that I won't need anymore.
The car is sold as is. Buyer responsible for pickup.
http://washingtondc.craigslist.org/nva/ ... 88801.html
Red/leather no roof Modded 104k $9950 VA
