1993 Teal/ leather no roof #1630 Ebay $29900 PA
Not sure what black Groments your are talking about, looks just like my Front cover except mine has vin sticker, also if you are referring to the two small holes, only GT's had push pins in those holes to hold an aluminum plate on the bottom side, Cobras did not use that plate because it would not clear the Inner Grill bracket.
I see no signs of vin sticker on front, what does this do to the value of this car?
IMO alot if you are buying this car for what it is supposed to be which is a new unmolested car. With the vin sticker MIA then you know something is up with that and it will come up for the rest of the life of the car that that sticker isnt there.aaronlstiles wrote:
On a side note it would be cool to have it because the mileage on it and my 1Le are exactly the same.
I'd hope someone didn't just peel it off, I know if I looking to buy I would be asking several questions. Maybe it's one that just didn't get put in the regular area, I'd hope.SPEEDFREEK wrote:IMO alot if you are buying this car for what it is supposed to be which is a new unmolested car. With the vin sticker MIA then you know something is up with that and it will come up for the rest of the life of the car that that sticker isnt there.aaronlstiles wrote:
Take another look at the pictures of the radiator support it appears to be fresh paint considerably brighter & smoother than the paint on the inner fenders. Its shows up where the support meets the fenders by the air box and also by the battery. Its a clean car but IMHO the nose has been worked on to some degree
K98Dave
88 LX hatch -(SOLD
1984 SVO number 110 (SOLD)
95 Lightning (SOLD)
86 LX Restoration in work)
88 LX hatch -(SOLD
95 Lightning (SOLD)
Look at the air bag sensor the lower bolt has had a wrench on it. And I'm with Aaron with the under coating that is exactly what it looks like coming out of the door drains and in the holes on the hood and the tops of the inner fenders. That would also explain the darker color of the floor pans. It looks like someone has tried to remove it. That would also be what is on the exhause pipes where it goes over the axel that looks burnt.
Where is the air bag sensor bolt?SPEEDFREEK wrote:Look at the air bag sensor the lower bolt has had a wrench on it. And I'm with Aaron with the under coating that is exactly what it looks like coming out of the door drains and in the holes on the hood and the tops of the inner fenders. That would also explain the darker color of the floor pans. It looks like someone has tried to remove it. That would also be what is on the exhause pipes where it goes over the axel that looks burnt.
SVT certificate is a re-print, the air bag sensor is by the front bumper bracket with the green bolts.
I asked him if he is the original owner and if he could verify that the car has never been damaged. I also noticed that the front bumper cover doesn't line up correctly with the drivers side molding at the front of the drivers side fender. Not sure if this was something that is common on these cars.
I know my 45 Mile car had a few light scratches on the bottom from being transported, so it is very possibly the front cover could have been damaged during original transport,
Both the SVT doc and window sticker are re-prints, my guess is, this car was just found by luck, and being flipped. I to noticed, the front cover was not lined up very well on the drivers side. Like I said, this would be a good car to have and drive once in a while.
