For sale 1993 Ford Mustang Cobra, Teal, Opal leather, no sunroof with 140k miles. Brand new motor, heads, turbo kit with less than 500 miles. I just had the front end repainted because of clear coat peeling, it does have a small dent on each rear quarter panel less than the size of a dime. Has a small oil leak coming from the oil pan. This car is a blast to drive and you will not be disappointed. Clear Texas title in hand. If you have any questions or want more pictures just shoot me an email.
Specs:
Forged 347 stroker motor original block studded and girdled
8.5 to 1 compression SRP pistons
All arp hardware
Trick flow 170cc twisted wedge heads
Cobra intake extrude honed by Kotzur Racing and powder coated black
Felpro MLS .041 thickness head gaskets
Trick flow push rods
Ford Racing 1.6 roller rockers
Comp Cam but not sure on specs, its a small cam setup for forced induction.
Edelbrock water pump
3 Core radiator with dual electric fans
On3performance turbo kit with a 70mm turbo.
MSD 6AL
MSD Distributor
MSD coil
Ford racing plug wires
3G alternator conversion
255lph fuel pump
42lb injectors
SCT BA5000 slot style maf
SCT flip chip
Specs for Transmission:
MMR TKO 600
Spec stage 3 clutch
Short shifter
FRPP aluminum driveshaft
Wheels/tires and suspension:
93 Cobra wheels 3 are in good shape and 1 wheel is very dull in finish
Rear tires are Nitto drag radials 275/45/17
Front tires are 245/45/17
Lowering springs
Car is tuned by Jeff Smith at Central Texas Performance.
On 9 psi car made 509rwhp and 501rwtq.
Call Jason 254.681.7234
asking 15000.00
Might take trades for muscle cars, lightning diesel gto ctsv camaro cobra mach 1 ( trades must be equal in value or have cash to go with )
I also have for sale:
2004 Mustang GT with 34k miles 4.6 SOHC with 5speed for 8750.00
1998 Mustang cobra with 106k miles for 6500.00
1964 Ford Falcon with 17" bullitts and a 93 Mustang 302 and C5 for 10500.00
http://dallas.craigslist.org/dal/cto/3621960228.html
Teal/Leather Turbo/347/TKO600 - $15k TX
