AM/FM, Bucket Seats, Cruise Control, Power Door Locks, Power Mirrors, Power Steering, Power Windows, Premium BFG 17 inch tires, Factory Cobra Wheels,Rear Defrost,Rear Spoiler, Sunroof, CD Player,Airbag Driver Side,Garaged,Non Smoker, AC, Power Brakes,No Rust, Good Paint, Good Original Black Cloth Upholstery, K&N Intake, RPM Front Suspension. New ACC Black Carpet.
This car hit that pole fairly hard and the body shop was not up to par. The hood and headlights are mis-aligned and the gaps in the inner fender and between the hood and top of front bumper are noticeable. Also, seller doesn't mention aftermarket taillights, valve covers, alternator and radiator. Also missing the coil cover and that's a novel way to connect the (-) cable to the battery.
That car needs some help. What's with the wire on the left strut stud? Looks like the core support and right apron were replaced, and the apron was not welded into the right place, over spray on the hood insulator, wrong right snake, missing interior hatch panel, too much corrosion under the hood for the miles, in addition to what's already been pointed out. And I bet more surprises when you get it on a lift. Driver car at best.
