http://www.ebay.com/itm/Ford-Mustang-Co ... s#viTabs_0
Vin# 1FACP42D0PF154768
Build# 1139
YOU'LL LOVE THIS TEAL COBRA...
CALL (LLAME) OR TEXT Paul 262-716-3269 for additional information and/or photos. (Se Habla Espanol)
1993 MUSTANG COBRA #1139 of 4993 -- TEAL BLUE METALLIC
Dyno'd @ 550+ RWHP
Beautiful, tastefully customized '93 Cobra: Original Parts NOT Included/Available
CAR SHOWS ONLY SINCE 1998 - NEVER RACED - NEEDS NOTHING - MECHANICALLY SOUND
PLEASE: SERIOUS BUYERS WITH FUNDS ONLY (NO JOYRIDES)
We have much more money into this car than asking price.
Odometer reads 23400, it rolled over once,in the later 1990's
Motor, tranny replaced within the last 5000 miles (a $14K investment).
DRIVETRAIN:
New(er) 331 ProBullet Crate Motor (Compression 8.9:1)
Vortech T-trim supercharger with bypass valve and 13 lb pulley
AFM Power Pipe
RHS Cylinder Heads
Typhoon Upper / Lower intake manifold (comparable to Edelbrock)
42 pound injectors with 75mm AirMeter
75mm Throttle body
Magna Fuel Pro Tuner Series fuel pump with fuel rails
MSD 6 BTM Timing Retard
Pro Racing 10.5 Wires and MSD BlasterCoil
Stock computer
3-Core Radiator w/160 degree thermostat
2 ½ inch MAC long tube headers
Pro-Chamber H-Pipe
Optima battery in rear compartment
New(er) TKO-500 5-spd manual transmission with Cobra R bell housing
3.73 Rear gears
TKO Shifter
Dual Friction Centerforce Stage 3 clutch
Adjustable clutch cable with quadrant
Aluminum drive shaft with safety loop
SUSPENSION/BRAKES:
Eibach Pro-Plus Springs and sway bars, upper and lower control arms and sub-frame connectors with upper and lower strut braces
Koni Caster/Camber platesCobra brakes w/cross-drilled slotted rotors
EXTERIOR AND INTERIOR:
Subtle Teal Ghost Flames (including inside hood)
Blue enhancing clear-coat
Cobra R Hood
Black Cobra racing seats with rear seat delete
Factory sunroof
Tinted windows
Polished and sealed original Cobra rims on BF Goodrich G-Force T/As (2nd set of Cobra R Rims w/tires negotiable or available for substitution)
Clear headlights
AutoMeter white face gauges (MPH, boost, fuel, oil temp, oil pressure, water temp, volts and air to fuel ratio))
Vehicle does not have a stereo "system" - comes with basic radio/CD/aux unit.
Serviced and build with the help of these Speed/Performance Players:
ASSC Racing Lake Bluff IL (now LRS Performance Inc. in Lake Villa IL)
Westech Automotive, Silver Lake WI
Vehicle has been in our family since about 1996. We are selling it to reduce the number of summer vehicles that we don't have time to drive.
Vehicle is located near Antioch, Illinois (zip 60002) and has rarely seen wet pavement and never snow.
You are welcome to have it inspected and shipped, or to fly out and trailer / drive it home!
