http://s1371.photobucket.com/user/belmo ... sort=3&o=0
Vin# 1FACP42D1PF154830
ENGINE:
FORD 347 STROKER
DART IRON EAGLE BLOCK 4.125 BORE
EAGLE 4340 CRANKSHAFT
EAGLE 4340 H-BEAM RODS
CUSTOM DIAMOND PISTONS
AFR 225 HEADS
MANLEY NEX-TEK VALVE SPRINGS
TITANIUM RETAINERS
COMP PRO-MAG 1.60R ROCKERS
RNH PERFORMANCE SOLID ROLLER CAM:
.50-.577/.577-218/218-114
CANTON 7QUART OIL PAN
75MM HOLLEY BILLET TB
60IBINJECTORS
HP PERFORMANCE 76MM TURBO
AIR TO AIR INTERCOOLER
44MM TIAL WASTEGATE
BILLET BLOW-OFF VALVE
1-3/4 HEADERS
3" TUBING-3.5" DOWNPIPE
AEROMOTIVE 1000 FUEL PUMP, FILTER AND REGULATOR
BBRC ALUMINUM FUEL CELL
STAINLESS STEEL LINES WITH AEROQUIP FITTINGS
MSD 6A IGNITION BOX
MSD WIRES, CAP, ROTOR
NGK SPARK PLUGS
CUSTOM DP RADIATOR
MMR TKO 900 TRANS
MCCLEOD CLUTCH
FIDANZA BILLET FLYWHEEL
ALU. DRIVESHAFT
SFI BELLHOUSING
8.8 REAR HOUSING
MOSER 9'BEARING ENDS
MOSER 31 SPLINE AXLES
3" STUDS
MOTIVE 3.73'S
EATON CARRIER
UPR ADJ. UPPERS/LOWERS
SUBFRAME CONNECTORS
DRIVESHAFT LOOP
AUTOMETER GAUGES
FAST XFI 2.0 EFI
650HP/600FT.IB. TORQUE
POWER LOCKS
POWER WINDOWS
POWER SEAT
AIR CONDITIONING
GREY CLOTH INTERIOR
STOCK FORD WHEELS
NEVER RACED-NO ¼ TIMES
BUILT BY RNH PERFORMANCE
EFI INSTALLED BY BELMONTS GARAGE
TUNED BY INJECTION CONNECTION-HORSHAM PA
650/600 ON 12IBS OF BOOST
93 OCTANE PUMP GAS
Do not contact me to waste my time. No low ballers, no tire kickers. Link to pictures works, you either know what you are buying or you do not.
NO TRADES
Link to pictures:
http://s1371.photobucket.com/user/belmo ... t=3&page=1
