Red-Black-Sunroof-xBob Kurgan car BIN $23k
Posted: Tue Apr 07, 2015 1:49 pm
http://www.ebay.com/itm/Ford-Mustang-Co ... 1628367763
Vin# 1FACP42D7PF175195
Build# 2933
Born 5/10/93
Build# 2933
Born 5/10/93
I purchased this Bob Kurgan built cobra, and have put some minor work into it, to make it my own. I drive truck for a living and have very little time to even bring it out. So rather than let it sit in a garage under cover, I decided to put it up for sale and let someone enjoy it as much as I have.
This is a real 1993 Ford Mustang Cobra SVT and was owned, built and raced professionally by Bob Kurgan. The vehicle has roughly 38 thousand miles on it and I have all the documentation on the vehicle, right down to window stickers, SVT Certs and documentation. When this vehicle was retired from drag racing, Bob Kurgan re-built it one last time as a street car. The vehicle is not for the faint of heart, I mostly drove it to shows and the occasional cruse here and there. But don’t be fooled, this street racing machine is race ready equipped, below are some of the Highlights of the build:
12 Point Cage fully tig welded xbar in rear, partial xbar in door, Window netting
Simpson cam-lock harnesses.
310 CI A4 Ford 4 bolt block with main and head studs. Bennett Racing PRO motor)
Sonny Bryant BILLET crank internally balanced.
Carrillo BILLET rods
ATI neutral balancer
JE custom pistons
Bennett racing Stage 3 TFS twisted wedge heads
Titanium retainers
Comp cams 1.6 Stud Rockers
Comp Cams custom blower grind
Sheet metal Valve covers
Holley Systemax intake ported by Bennett
Custom 2 inch headers to 3.5 inch collector and Borla Xr-1 stainless mufflers
Vortech YSI supercharger pullied for30+ psi
Griffin 4 row radiator and dual flexalite pusher fans
Dynamic mighty mite C4 with trans-brake and with PTC torque converter
Cheetah Shifter
Big stuff 3 standalone EMS with internal logger
MSD distributor for use with Big Stuff 3
5 Autometer gauges + 5 inch tachometer and shift light
Gauge pod and Gauge Cage
Harwood 4 inch cowl induction hood.
Weldon 2025 fuel pump and 20 Gallon fuel cell
-10 feed and -6 return braided lines with Paxton regulator
Heavy Duty Trans cooler
TRZ complete rear suspension
D7D complete tube front suspension
Avo front and rear adjustable shocks/struts.
Strange master cylinder and proportioning valve
Hurst line-lock.
MM Caster Camber Plates3g 130 amp alternator
Optima Battery
