C/O 93 Mustang Cobra termi-swapped 3.4L Whipple
Posted: Tue Jun 20, 2017 1:27 pm
by Rob_stylez
Good lord I love this car, one of my favorite on Instagram for sure :)
http://www.ebay.com/itm/1993-Ford-Musta ... iF&vxp=mtr
If you want one of the baddest street foxbody magazine car, here it is!!!
Took me a while to make this decision but need the extra cash to move into a bigger home.
This is a REAL 1993 Cobra #769 with the best of the best, it's a dream car for sure.
I'm the 3rd owner and had it for 3 years, first owner did a full color change to Ford's competition orange, also swapped a full motor and drivetrain including all the wiring harnesses out of a wrecked '03 Cobra with 24k miles on it.
Second owner had it for a few months and barely put any miles on it until I bought it off him.
Unfortunately after I bought it, cylinder #8 let go, we had to do a complete rebuild on the engine and upgraded many components, car now is a beast and drives very smooth even with the big cams it has.
Car was featured on MM&FF magazine on May 2010 as "Orange Dream Machine"
It's been tuned by the best in business, Bob Kurgan of Kurgan Motorsports, makes 770rwhp on a conservative tune, it has plenty of power left but no point on adding more to this light weight car.
body has nearly 100k miles, all components swapped from the newer cobra have 30k miles. Engine, clutch, oil pump, cams, fuel pumps and injectors have less than 1k miles.
Here's a list of modifications:
Engine:
03 cobra stock iron block .020 bored over
Cp Pistons 8.5:1 C/R
Comp cams stage 3 cams
Comp cams springs and retainers
Meilling oil pump
Kooks 1 7/8 long tube headers
3" collectors
3" off road Kooks X pipe
3" magnaflow magnapack catback (loud )
3.4L 2nd generation whipple supercharger
Single blade throttle body
JLT intake tube
VMP3500 maf sensor
Metco 100mm wrap idler pulley
Cooling head mod
Killer chiller system
AEM methanol injection kit (installed but not used)
SCT hand held tuner
Drivetrain:
03 Cobra stock T56 with upgraded 26 spline input shaft
McLoud rxt clutch (1k hp)
Mgw shifter
Aluminum driveshaft
8.8 rear end with tubes welded
31 spline ford racing fox lenght axles
3.55 gears
03 cobra differential with carbon clutches
Fuel system:
Return style fuel system
03 cobra fuel tank sumped
-10 braided stainless feed line
-8 return line
Twin Bosch 044 fuel pumps (1500hp)
Aeromotive fuel filter and regulator
Fore fuel rails
ID 1000 injectors
MM subframe connectors
MM caster camber plates
Reinforced torque boxes
Brakes:
Brembo 4 piston front calipers
14" Brembo drilled/slotted rotors
99-04 cobra rear brakes
03 cobra hydrobooster
Stainless braided brake lines
Rear drilled/slotted rotors
Wheels:
True Forged mach 5 step lip ($3.5k)
Brushed double tinted centers
Polished lips
18x8 front, 18x10 rear
245/35/18 Bfg KDW front tires (65% left)
295/35/18 Bfg drag radial rear tires (70% left)
Interior:
04 cobra front seats (like new)
93 cobra rear seats reupholstered to match front seats (new)
03 cobra gauge cluster
03 cobra steering wheel and column
03 cobra pedal assembly
MM 6pt weld-in roll bar with swing out door bars
Jvc stereo
Boost gauge, wideband and water temp gauge
N2MB wot box/2-step
Exterior:
Original 93 cobra body parts
Cervinis cobra R hood with shaved edges and logo
Smoked headlights and fog lights
Tinted windows
This is an amazing build with tons of money invested, it would take $70K+ to build one like this kind from scratch, turns heads and gets compliments all the time, also had won few trophies at car shows.
Only flaws are on the front bumper, paint cracked on 3 spots, can't really tell from a few feet away. Exterior is 9.5/10 and interior 9.5/10.
Will ship at buyers expenses. An immediate deposit of $500 is required.
Please don't bid if you don't have the money on hand, thanks.
