Teal/Silver Grey $15k TX
SVT4942
Post by SVT4942 »
https://austin.craigslist.org/cto/d/199 ... 29433.html
The vehicle runs perfectly, shifts smoothly, and fast! Most recent ads or repairs include new paint job, new headlamps, A/C reworked, new battery, new remote mirror switch, new floor matts and new parking brake. This vehicle is exempt from the odometer reading. It reads 06481 but I cannot confirm that this is accurate. Mechanical features include:
Tubular K Frame and Control Arms Suspension
Cobra R Wheels
D & D Coil Cover
Factory Disc Brakes
76MM on Three Performance Turbo
Mishimoto Radiator and Electric Fans
e303 Cam
Girdled Block
331 Stroker
GT40X Aluminum Heads
Forged Mahle Heads
9:0:1 Compression Ratio
½ inch Plenum Spacer
Ford Racing 30 lbs Injectors
BBK Cold Air Intake
Summit Racing 75MM MAF (calibrated for the 30 lbs injectors)
BBK 75MM Throttle Body
Ford Racing 8 MM Plug Wires
MSD Streetfire Ignition Coil
New MSD Distributor Cap and Rotor
New 180 Degree Thermostat and Housing
All New Gaskets
Prothane Urethane Motor Mounts
Welded Subframe Connectors
Built t5 Trans with PRO 5.0 Shifter
New Shifter Boot and Seal
King Cobra 10.5" Clutch
Aluminum Drive Shaft
BBK Shorty Headers
Hiflow Cats
Flowmaster 40s
New Hawk Ceramic Front and Rear Pads
New National Wheel Bearings
New Master Cylinder and Brake Booster
Real Brake Proportioning Valve
New Parking Brake Cables
New Parking Brake handle and Assembly
Stainless Steel Braided Brake Lines
Sn95 Accessories (AC Compressor and Power Steering)
All New Sensors
All New Relays and Fuses
130 amp 3G Alternator Conversion
Smog Delete
New Fuel Tank
New BBK 340 lph Fuel Pump
3.08 Gears
Lowering Springs
New Real Upper and Lower Control Arms
New Speedo Gear and Sensor
Asking $15,500 negotiable
Contact: Seven One Three - Two Zero One - Zero Zero Seven Seven
93 EY/C6 13C #12
93 RD/DJ #2304
93 RD/DJ 13C #4942
