Door moulding refurbishment
stubes
Post by stubes »
I own a lower mile teal car.
My door mouldings have a slight discolor to them and are original.
Doing a search, I found paint thinner will clean them up to look like new?
Is lacquer thinner ok to use? Or what kind of thinner?
I don't want to use the wrong stuff and harm them!
Re: Door moulding refurbishment
I've used what automotive body shops call pre-cleaner worked pretty well. Maybe mineral spirits will work also, just make sure you put a small amount on a towel then wipe.
yeah lacquer thinner is probably too harsh
stubes
Post by stubes »
Ok, I have some of the body shop pre cleaner stuff also also, as well as that body shop wax and grease remover stuff. I guess both are kind of the same.
Anyways I was thinking lacquer thinner would be too harsh too.
SPEEDFREEK
Post by SPEEDFREEK »
I use lacquer thinner and never a problem.
93N8
Post by 93N8 »
I just used laquer thinner on a towel and waxed the hell out of it. You just swipe it across it all. Just don't scrub it to death
'93' Cobra #761
Red/grey
POOBLAH
site grease monkey
Post by POOBLAH »
SPEEDFREEK wrote:I use lacquer thinner and never a problem.
Yea I used Mineral Sprints for most of my cleaning and have never had an issue.
The only thing it doesn't clean good is anything rubber. (Like rubber bushings and isolators)
It eats at the rubber slightly.
DemoDH
Post by DemoDH »
when I worked at a detail shop we used a product called Rubbercare.
just sprayed it on like paint and wiped off the excess. It worked great on plastic parts too.
#923 teal/grey cloth 165k- (SOLD)
#861 red/grey cloth 70k- Just purchased
92 Hatch blue/silver 150k- My first fox
2010 4runner family wagon- Haha
and a couple bikes
