Picked up this teal cobra this past Nov. So far I added blower with 8" lower/ 2.95 upper, 60lb injectors, diablo chip, mafia, msd 6btm, pro-m 80 mm mass air,75 R accufab, aeromotive 340 pump and rails, "4 hood. Car came with Fox Lake cnc ported trick flows, stage 2 cam, systemax, full exhaust, etc.
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
Z282SLO wrote:Polished Vortech S/C ... a perfect add-on.
Have you had it on the dyno?
Not yet but this same blower (with 7" crank and 2.95 blower pulley) on my 93 coupe with stock short block with heads, intake, cam, etc made 548rwhp. It should be around the same when i get it tuned. Still need to add ignition and fuel pump.
93 coupe 91mm turbo
escogt wrote:^^ You put an auto in your Cobra??? ^^
Yes. I have tried world class, 3550's, and a tko 500 in other cars. AOD is the only way to go in a street car. This same AOD and converter and s-trim went 1.36 60ft and 6.18 1/8th mile footbreaking on a 275/50/15 drag radial in my last car. I know some will hate that I put a AOD in a cobra but I enjoy the car much more this way.
93 coupe 91mm turbo
