Want to trade built, 1993 Cobra for a 2003-2004 Cobra. I have a list of everything done to it etc. email is best. Open to other trades as well. Looking for a new toy.
Want to sell or trade 1993 Mustang Cobra
http://omaha.craigslist.org/cto/5121768657.html
Re: Want to sell or trade 1993 Mustang Cobra
http://omaha.craigslist.org/cto/5145541528.html
Vin# 1facp42d7pf178078
Build# 4495
Born 6/15
Build# 4495
Born 6/15
email or text me with serious inquiries. A lot has been done to it. Adult owned and driven. All vin tags in place, minus the cowl hood. I have the original hood as well.
1993 Cobra #4495
347 Stoker (Stock block) 10.8 comp
- Probe SRS Forged Pistons, flat top -4.0cc (+.30") - Moly Rings
- SCAT forged steel crankshaft
- SCAT I-Beam Forged Rods
- Probe Industries Street Fighter Main Girdle Kit
28oz flywheel and balancer (SFI)
Canton 7 qt oil pan
Summit Racing billet distributor
Victor Jr Heads 60cc
Harland Sharp 1.6 roller rockers
Trick Flow TFS 3 cam (51403003)
Trick Flow TFS Box R intake
255lph fuel pump
Aeromotive fuel pressure regulator
AN fuel line from tank to fuel rail w/press.guage
42lb injectors
Anderson 4" Power Pipe
Accufab 90mm Throttle Body
Abaco 97mm Mass Air Meter
K&N Air Filter
MAC long tubes 1 3/4 primaries
MAC 3" prochamber
MAC 3" mufflers
Flowmaster 3" stainless tips
T5z transmission
RamHDX Clutch with steeda everything
Aluminum driveshaft
3.73 Gears
3G upgraded alternator
MSD Ignition Coil
Ford Racing Spark Plug Wires
Mishimoto Aluminum Radiator
Electric fan
Corbeau TRS seats w/ correct Corbeau brackets
Gray carpet with OEM mats
Corbeau Harness bar
3" RCI Race 5 point SFI Harness
Autometer
- 5" Tachometer
- 2 5/8 Coolant Temp
- 2 5/8 Oil Pressure
5 Lug converted with SN95 axles
2003 Cobra Brakes
BAER 2 piece brake rotors front + rear
20% tint all around including sunroof
Boss Inc Pro cowl hood and stock hood.
Drag 31 wheels 17x9 black
Falken Azenis 615RT tires 245/45/17 + 275/40/17
**also have a set of Roush Stage 3 wheels powdercoated black with the logo painted in car color 18x9 and 18x10. Can be negotiated in deal
Bump Steer Kit
Strange adjustable front coil overs with 350lb springs
Strange adjustable rear shocks
Summit Racing Caster Camber plates
J&M weight jackers with cobra springs
SCT tuned chip
HID headlights
Smoked 6pcs headlight set
Car Cover
