Bucking problem
Bucking problem
when i release the clutch at low rpm .. the car buck's & jerks bad , push in the clutch it go away ?
Thanks
Clint
Thanks
Clint
Re: Bucking problem
O2 Sensor? Guys back me up
Re: Bucking problem
Might be the upper intake gasket, have you done any work lately?
Re: Bucking problem
i change the O2 sensor out.still the same ...6 months i change MSD ,Distributor,coil ,wires,plugs..it did not buck after i change out all of that ...i ran a scan and the only code that I'm getting is 67 ..
Clint
Clint
Re: Bucking problem
recently i started to hear a ticking sound.WillyB93 wrote:Might be the upper intake gasket, have you done any work lately?
Re: Bucking problem
As in idle RPM's?SVT#3140 wrote: when i release the clutch at low rpm .. the car buck's & jerks bad , push in the clutch it go away ?
Thanks
Clint
If you are letting the clutch out quickly at low RPM's and essentially idling in gear with the car bucking, it's just slop in the drivetrain. Give it a little gas and SLOWLY release the clutch and you won't have that problem.
Re: Bucking problem
Goose17 wrote:As in idle RPM's?SVT#3140 wrote: when i release the clutch at low rpm .. the car buck's & jerks bad , push in the clutch it go away ?
Thanks
Clint
RPM idle .letting clutch slowly still the same ,give it a little gas still bucking .
Re: Bucking problem
Most of my Mustangs do the same. Give it some gas and let out the clutch while feeding-in more gas and it won't buck. Don't try to idle in first gear.SVT#3140 wrote:Goose17 wrote:As in idle RPM's?SVT#3140 wrote: when i release the clutch at low rpm .. the car buck's & jerks bad , push in the clutch it go away ?
Thanks
Clint
Re: Bucking problem
i change the upper intake gasket today ..still the same .
Re: Bucking problem
put in a 3.73 gear,,that will fix it.
Re: Bucking problem
noac wrote:put in a 3.73 gear,,that will fix it.
I have 3.73 gears.
Re: Bucking problem
At this point, a skilled mechanic may be helpful. Good luck.
Re: Bucking problem
Have you replaced the neutral gear switch in the transmission? I did a quick Google search and that could be a possibility,just throwing it out there good luck.
Re: Bucking problem
did not replaced the neutral gear switch..i'm looking into now .....thankssc-rcode wrote:Have you replaced the neutral gear switch in the transmission? I did a quick Google search and that could be a possibility,just throwing it out there good luck.
Re: Bucking problem
I believe my car is doing the same thing
93 Cobra
Black/Black
43K miles and counting
No major mods just exhaust (can't be without the rumble):
pretty much all original
Black/Black
