I do not need to sell this car! I am only considering it. I reserve the right to cancel until money exchanges hands
Limited production of 4993, of these car were produced.
This one is vibrant red clear coat, with gray cloth seats. I believe this color and interior combination is 1 out of 1000 of the total 4993 produced.
Ford's 5.0L engine used in the GT Mustang had many modifications done to it before being fit into the Cobras. Among these changes were higher-performance GT-40 cylinder heads, larger valves, and a stouter camshaft.
The same Borg-Warner T-5 transmission found on the GT was used for the Cobras, except it came with phosphate-coated gears as well as stronger bearings. Goodyear Eagle P245/45ZR17 tires were mounted on 17x7.5 inch aluminum wheels. Also on the Cobra were rear vented disc brakes instead of the standard drum brakes.
The Cobra had the same lower grille as the GT, but minus the side scoops. The front fascia contained a grille opening which carried a running horse emblem. The one-piece fascia in the rear had cutouts for the exhaust tips, as well as a rear spoiler.
