So I drove the cobra today and recorded this info:
4th gear - 40mph - 1600rpm
5th gear - 55mph - 1500rpm
5th gear - 70mph - 1900rpm
Can anyone with the stock 3.08 confirm that mine is not 3.08?
Possible Gear Change?
- dustin9187
Re: Possible Gear Change?
#732
Black / Grey cloth
Black / Grey cloth
Based on this website and assuming stock tires you have 3.08 gears.
http://www.bgsoflex.com/rpmmph.html
From what I recall, if your just under 2k at 70mph, that would be a 3.08 rear.
I know for a fact I have a 3:55. I never knew if the speedo was correct. But today at 55mph in 5th gear I was at 1750rpm. Then I got lucky and I was driving thru my neighborhood and there was radar parked on the road and it was telling me I was going 25mph and my speedo showed 28/29mph. So now I know the gear was never changed. So I hope this helps
'93' Cobra #761
Red/grey
Red/grey
- jstanley55
Jack the rear of your car up, mark the driveshaft and a point on the tire, sping your tire 10 full revolutions and count the number of driveshaft rotations while you spin the rear tire. Then divide the number of driveshaft rotations by the number of tire rotations (10). This will give your your ratio. Then buy the appropriate speedo gear and you should be good to go.
jstanley55 wrote:Jack the rear of your car up, mark the driveshaft and a point on the tire, sping your tire 10 full revolutions and count the number of driveshaft rotations while you spin the rear tire. Then divide the number of driveshaft rotations by the number of tire rotations (10). This will give your your ratio. Then buy the appropriate speedo gear and you should be good to go.
Cool! Thx man!
'93' Cobra #761
Red/grey
Red/grey
- dustin9187
OK well then according to the rpm / speed info, my gears ARE stock. So why do i have the odometer differences?
#732
Black / Grey cloth
Black / Grey cloth
