Question about my hand brake Assembly
Kilrgt
Post by Kilrgt »
I know that the hand brake assembly has never been a solid part in the car, mine i think is way worse then normal, can you all have a look at the vid and pics and tell me if something is wrong , the problem with mine is it seems way way loose then the fox bodies iv had in the past, the only reason i car is because its damaging the rubber gasket and i want to replace it and if the hand brake needs to be replaced ill do that at the same time/
I know photobucket is painfully slow and hope the vid loads.
So what do yall think?
http://vid969.photobucket.com/albums/ae ... i3gzkn.mp4
Re: Question about my hand brake Assembly
It does look way loose, I would either find a way to tighten that up or replace before you put the new rubber on it.
POOBLAH
site grease monkey
Post by POOBLAH »
Yea, that seems excessive!
Is it pulling up to high? or always pulling to the side. (Somehow it doesn't feel right asking this question... lol)
Kilrgt
Post by Kilrgt »
HAHA yea i can see why,
Its pulling to side and its pulling a little too high I think, for the cost of them I think Ill find a new one and replace. Not sure how hard of a job it is but hey its a fox body no jog is real tough on these.
Thanks for the replies guys
POOBLAH
site grease monkey
Post by POOBLAH »
If its too high, then you may need new brake pads or your cables are worn (stretched too far)
Kilrgt
Post by Kilrgt »
*** Edit****
Quick question, iv been seeing online that I may have to modify the new handbrake assembly, something about cutting a spring and welding the self
adjustment to the second tooth, can any of you please confirm is this is true??
Thanks All ..again
I found a NOS assembly and will be installing it, it was way too loose for my liking. Thanks for the input guys
