347 installed
Ysi91
347 installed
Post by Ysi91 »
Removed the 112k mile stock shortblock to fix oil pan and rear main leak. Once out I decided to change things up alitte. 347ci in a B50 block.
http://youtu.be/KTtg5ZbDNiM
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
lukewood2
Re: 347 installed
Post by lukewood2 »
Nice! HP?
Ysi91
Re: 347 installed
Post by Ysi91 »
lukewood2 wrote:Nice! HP?
Thanks and don't know. It made 511 at the wheels though an AOD with the stock shortblock.
93 coupe 91mm turbo
Re: 347 installed
Why do you run a AOD, drag the car?
jsmithgt500
Re: 347 installed
Post by jsmithgt500 »
Great Looking car! Sounds mean!!
Ysi91
Re: 347 installed
Post by Ysi91 »
Thanks.
I used to be a die hard 5spd guy. From stock 5 spds to world class to tremec 3550 to a tko 500. Finally tried an auto. For me and N/A car is fun with a 5spd but a blower/auto with the right converter is very nice.
93 coupe 91mm turbo
